find references: same file found more than once
Sysprogs forums Forums VisualGDB find references: same file found more than once
  • #23982
    the locations of functions are found multiple times. This is probably because multiple project in my solution share the same files. (See at https://github.com/thelsing/knx )
    Could you fix this please:
    Steps to reproduce:
    • Open solution, open apdu.cpp of knxLinux project. Select “Find all references” for any method in the file. I think the same error is also in there in the “references” tab of the avanced view of a function.
    Regards,
    Thomas
    #24026
    No problem, please try this build: VisualGDB-5.4.103.2933.msi
