Sysprogs forums › Forums › VisualGDB › FastSemihosting and InstrumentingProfiler Warnings
- This topic has 2 replies, 2 voices, and was last updated 7 years, 8 months ago by
Seidleroni.
July 23, 2018 at 16:13 #21444
Seidleroni
ParticipantWhen I compile my STM32 project that includes FastSemihosting and the InstrumentingProfiler, I get a handful of warnings. Obviously the project works even with these warnings, but it would be great to update these files so they compile without warnings. Would it be possible to have these updated?
Warning unused variable ‘pSemihostingStruct’ [-Wunused-variable] _visualgdb C:\Users\xxxx\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\FastSemihosting.cpp 56
Warning comparison between signed and unsigned integer expressions [-Wsign-compare] _visualgdb C:\Users\jseidmann\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\FastSemihosting.cpp 261
Warning comparison between signed and unsigned integer expressions [-Wsign-compare] _visualgdb C:\Users\jseidmann\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\FastSemihosting.cpp 264
Warning comparison between signed and unsigned integer expressions [-Wsign-compare] _visualgdb C:\Users\jseidmann\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\InstrumentingProfiler.cpp 218
Warning comparison between signed and unsigned integer expressions [-Wsign-compare] _visualgdb C:\Users\jseidmann\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\InstrumentingProfiler.cpp 705
Warning comparison between signed and unsigned integer expressions [-Wsign-compare] _visualgdb C:\Users\jseidmann\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\InstrumentingProfiler.cpp 717
Warning comparison between signed and unsigned integer expressions [-Wsign-compare] _visualgdb C:\Users\jseidmann\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\InstrumentingProfiler.cpp 738
Warning this ‘if’ clause does not guard… [-Wmisleading-indentation] _visualgdb C:\Users\jseidmann\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\FastSemihosting.cpp 287<hr />
1>C:/Users/xxxx/AppData/Local/VisualGDB/EmbeddedEFPs/Profiler/FastSemihosting.cpp: In function ‘void InitializeFastSemihosting()’:
1>C:\Users\xxxx\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\FastSemihosting.cpp(56,8): warning : unused variable ‘pSemihostingStruct’ [-Wunused-variable]
1> void *pSemihostingStruct = &s_FastSemihostingState;
1> ^~~~~~~~~~~~~~~~~~
1>C:/Users/xxxx/AppData/Local/VisualGDB/EmbeddedEFPs/Profiler/FastSemihosting.cpp: In function ‘int SysprogsProfiler_WriteData(ProfilerDataChannel, const void*, unsigned int, const void*, unsigned int)’:
1>C:\Users\xxxx\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\FastSemihosting.cpp(261,18): warning : comparison between signed and unsigned integer expressions [-Wsign-compare]
1> if (done != headerSize)
1> ~~~~~^~~~~~~~~~~~~
1>C:\Users\xxxx\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\FastSemihosting.cpp(264,18): warning : comparison between signed and unsigned integer expressions [-Wsign-compare]
1> if (done != payloadSize)
1> ~~~~~^~~~~~~~~~~~~~
1>C:/Users/xxxx/AppData/Local/VisualGDB/EmbeddedEFPs/Profiler/FastSemihosting.cpp: In function ‘void SuspendFastSemihostingPolling()’:
1>C:\Users\xxxx\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\FastSemihosting.cpp(287,5): warning : this ‘if’ clause does not guard… [-Wmisleading-indentation]
1> if (!CanInvokeSemihostingCalls())
1> ^~
1>C:\Users\xxxx\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\FastSemihosting.cpp(290,2): note : …this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
1> asm volatile(“mov r0, %1; mov r1, %0; bkpt %a2″::”r” (0), “r” (SysprogsSemihostingReasonBase + kControlFastSemihostingPolling), “i” (AngelSWI) : “r0”, “r1”, “r2”, “r3”, “ip”, “lr”, “memory”, “cc”);
1> ^~~
1>stm32f7xx_hal_flash.c
1>stm32f7xx_hal_flash_ex.c
1>stm32f7xx_hal_gpio.c
1>stm32f7xx_hal_i2c.c
1>C:/Users/xxxx/AppData/Local/VisualGDB/EmbeddedEFPs/Profiler/InstrumentingProfiler.cpp: In member function ‘SysprogsInstrumentingProfiler::InstrumentedFrame* SysprogsInstrumentingProfiler::InstrumentedFramePool::AllocateFrame()’:
1>C:\Users\xxxx\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\InstrumentingProfiler.cpp(218,35): warning : comparison between signed and unsigned integer expressions [-Wsign-compare]
1> for (int i = 0; i < __countof(m_FramePool) – 1; i++)
1> ~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~
1>stm32f7xx_hal_i2c_ex.c
1>C:/Users/xxxx/AppData/Local/VisualGDB/EmbeddedEFPs/Profiler/InstrumentingProfiler.cpp: In function ‘void SysprogsProfiler_RTOSThreadSwitched(void*, const char*, void*)’:
1>C:\Users\xxxx\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\InstrumentingProfiler.cpp(705,27): warning : comparison between signed and unsigned integer expressions [-Wsign-compare]
1> for (int i = 0; i < __countof(SysprogsInstrumentingProfiler::s_AllThreadRecords); i++)
1> ^
1>C:\Users\xxxx\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\InstrumentingProfiler.cpp(717,27): warning : comparison between signed and unsigned integer expressions [-Wsign-compare]
1> ^
1>C:/Users/xxxx/AppData/Local/VisualGDB/EmbeddedEFPs/Profiler/InstrumentingProfiler.cpp: In function ‘void SysprogsProfiler_RTOSThreadDeleted(void*)’:
1>C:\Users\xxxx\AppData\Local\VisualGDB\EmbeddedEFPs\Profiler\InstrumentingProfiler.cpp(738,23): warning : comparison between signed and unsigned integer expressions [-Wsign-compare]
1> ^July 23, 2018 at 19:54 #21447support
No problem. We have rechecked our profiler framework in the maximum warning mode and took care of the most issues. Please update to the latest 2.17 package.
If you would like to resolve any further advanced warnings, please send us a patch based on the v2.17 package source and we should be able to integrate it into our source tree (as long as it doesn’t break any functionality).
July 23, 2018 at 20:19 #21450Seidleroni
ParticipantThat resolved all of the warnings, thank you very much.
