Sysprogs forums › Forums › VisualGDB › Fail: https://visualgdb.com/tutorials/esp32/
- This topic has 6 replies, 2 voices, and was last updated 9 years, 4 months ago by
donvukovic.
June 9, 2017 at 19:30 #11442
donvukovic
ParticipantI have been trying for days to get this tutorial to work.
At step 10, I get an “unable to connect message”.
I have re-installed VisualGDB, I have reloaded the Olimex drivers, ( re-installing V_GDB and re-starting VS2017 community says the driver is wrong for OpenOCD and reinstalled the correct driver) (thank you)
But I still get the timeout error.
What can I check, re-install or do, to get this working.
June 9, 2017 at 20:14 #11443support
This depends on the exact type of error you get. Could you paste the entire log from “test OpenOCD settings” here?
June 9, 2017 at 20:24 #11444donvukovic
ParticipantC:\SysGCC\esp32\esp32-bsp\OpenOCD\bin\openocd.exe -f interface/ftdi/olimex-arm-usb-ocd-h.cfg -f target/esp32.cfg -c “adapter_khz 3000”
Open On-Chip Debugger 0.9.0 (2017-05-09)
Licensed under GNU GPL v2
For bug reports, read
Info : auto-selecting first available session transport “jtag”. To override use ‘transport select <transport>’.
adapter speed: 3000 kHz
Info : clock speed 3000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Trying to use configured scan chain anyway…
Error: esp32.cpu0: IR capture error; saw 0x1f not 0x01
Info : esp32.cpu0: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32.cpu0: Core was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32.cpu1: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32.cpu1: Core was reset (pwrstat=0xFF, after clear 0xFF).
Info : accepting ‘telnet’ connection on tcp/4444
shutdown command invoked
Info : dropped ‘telnet’ connectionJune 9, 2017 at 20:28 #11445support
This looks like a JTAG wiring problem. Please double-check the JTAG pins you are using and ensure you have no other hardware connected to them.
June 9, 2017 at 20:55 #11446donvukovic
Info : esp32.cpu0: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32.cpu0: Core was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32.cpu1: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32.cpu1: Core was reset (pwrstat=0x5F, after clear 0x0F).
Info : dropped ‘telnet’ connectionJune 9, 2017 at 22:17 #11447donvukovic
ParticipantContinuing to follow the ../tutorials/esp32
At step 16:
Your VisualGDB trial expires in 25 days!
C:\SysGCC\esp32\bin\xtensa-esp32-msvs-gdb.exe –interpreter mi C:\Users\Donald\Documents\visualStudio2017\Projects\ESP32DEMO\VisualGDB\Debug\ESP32DEMO
-gdb-version
=thread-group-added,id=”i1″
GNU gdb (GDB) 7.10
Copyright (C) 2015 Free Software Foundation, Inc.
This GDB was configured as “–host=i686-pc-mingw32 –target=xtensa-esp32-elf”.
For help, type “help”.
Reading symbols from C:\Users\Donald\Documents\visualStudio2017\Projects\ESP32DEMO\VisualGDB\Debug\ESP32DEMO…
done.
GNU gdb (GDB) 7.10
OK
-list-features
No symbol “disassembly” in current context.
-gdb-set print demangle off
OK
-break-insert -f main
&”Function \”main\” not defined.\n”
-break-delete 1
OK
target remote :3333
&”target remote :3333\n”
Remote debugging using :3333
=thread-created,id=”2″,group-id=”i1″
../../../../src/gdb-7.10/gdb/inline-frame.c:171: internal-error: inline_frame_this_id: Assertion `!frame_id_eq (*this_id, outer_frame_id)’ failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
Quit this debugging session?
(y or n) [answered Y; input not from terminal]
&”\nThis is a bug, please report it.”
&” For instructions, see:\n<http://www.gnu.org/software/gdb/bugs/>.”
&”\n\n”
Create a core file of GDB?
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.
vj+z1: GDB session exited prematurely. Please verify that the project is built, the selected GDB binary exists and the working directory is specified correctly.at vj.b2()
at VisualGDB.GDBDebugEngine.d1(rw b, a a)
June 9, 2017 at 23:17 #11448donvukovic
ParticipantOK, I found it. Reset the board.
