Extra parameters with Debug APK on Android
Sysprogs forums Forums VisualGDB Extra parameters with Debug APK on Android
  • #627
    cpuser
    Is there a way to pass extra parameters when using debug APK on Android?
    For example, I’d like to start the executable with something like this:
    %ADB% shell am start –activity-clear-top -n %PACKAGE%/%ACTIVITY% –es %EXTRASTRING% stringValue -t application/vnd.myapp.ext+ext -d file:///storage/emulated/0/%FILE%
    Thanks.
    #2597
    ket
    Currently, no. The option to add extra parameters to “am start” is planned to be added into the upcoming 4.1 version.
    #2598
    cpuser
    Ok, thanks, that would be extremely useful, especially since you support saving the debug APK parameters under a given name. That would make for a great experience.
    In the meantime, a co-worker showed me that I can simply call the start the command with parameters with adb manually after the executable is already started under the debugger, and I am getting the proper code path executed in my code.
    Thanks!
