“espidf.constraints.v5.4.txt doesn’t exist” error
Sysprogs forums Forums VisualGDB “espidf.constraints.v5.4.txt doesn’t exist” error
  • #36481
    gigamegawatts
    I updated VisualGDB to the latest ESP32 package today.
    Afterwards, when I loaded an ESP32 project I got an error during the CMake configuration:
    -- Checking Python dependencies...
    ERROR: C:\Users\gigam\.espressif\espidf.constraints.v5.4.txt doesn't exist. Perhaps you've forgotten to run the install scripts. Please check the installation guide for more information.
    CMake Error at C:/SysGCC/esp32/esp-idf/v5.4/tools/cmake/build.cmake:422 (message):
    Some Python dependencies must be installed. Check above message for
    details.
    C:/SysGCC/esp32/esp-idf/v5.4/tools/cmake/build.cmake:560 (__build_check_python)
    C:/SysGCC/esp32/esp-idf/v5.4/tools/cmake/project.cmake:717 (idf_build_process)
    CMakeLists.txt:6 (project)
    I fixed the error by copying espidf.constraints.v5.4.txt from c:\espressif.
    I remember getting the same type of error after installing the previous ESP32 update package.
    Is there something wrong with my VisualGDB configuration that is causing it to look in the wrong directory?
    (I’m using the latest version of VisualGDB: 6.0R7).
    Dan.
    #36483
    Please try creating a new project using the wizard. It should initialize the Python environment correctly.
    #36484
    gigamegawatts
    OK, thanks.
    I noticed that I had an IDF_PATH environment variable set to c:\espressif.  I don’t think there’s any good reason for that to be there, so I removed it.
    Perhaps that environment variable is what led to the problem?
    In any case, all is working now.
    Dan
