Sysprogs forums › Forums › VisualGDB › ESP8266 undefined reference to `smartconfig_stop'
- This topic has 6 replies, 3 voices, and was last updated 8 years, 3 months ago by
July 18, 2017 at 02:59 #11735
Yuex.S
Participantundefined reference to `smartconfig_stop’ 04SmartConfig E:\Project\ESP8266\Project\04SmartConfig\04SmartConfig\VisualGDB\Debug\LEDBlink.o 1
my code
#ifdef __cplusplus
extern “C”
#endif#include <esp_common.h>
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include <pin_mux_register.h>
#include <gpio.h>
#include <uart.h>#include “espressif/espconn.h”
#include <smartconfig.h>
#include “lwip/sockets.h”
#include “lwip/dns.h”
#include “lwip/netdb.h”void user_init(void);
#ifdef __cplusplus
#endif#ifdef ESP8266_GDBSTUB
#include <gdbstub.h>
#endif#define RAMFUNC __attribute__((section(“.entry.text”)))
static void RAMFUNC LEDBlinkTask(void *pvParameters)
for (int tick = 0;;tick++)
vTaskDelay(300 / portTICK_RATE_MS);
gpio_output_conf(0, BIT2, BIT2, 0);
gpio_output_conf(BIT2, 0, BIT2, 0);
}void ICACHE_FLASH_ATTR
smartconfig_done(sc_status status, void *pdata)
switch (status) {
case SC_STATUS_WAIT:
printf(“SC_STATUS_WAIT\n”);
break;
case SC_STATUS_FIND_CHANNEL:
printf(“SC_STATUS_FIND_CHANNEL\n”);
break;
case SC_STATUS_GETTING_SSID_PSWD:
printf(“SC_STATUS_GETTING_SSID_PSWD\n”);
sc_type *type = pdata;
if (*type == SC_TYPE_ESPTOUCH) {
printf(“SC_TYPE:SC_TYPE_ESPTOUCH\n”);
else {
printf(“SC_TYPE:SC_TYPE_AIRKISS\n”);
break;
case SC_STATUS_LINK:
printf(“SC_STATUS_LINK\n”);
struct station_config *sta_conf = pdata;wifi_station_set_config(sta_conf);
wifi_station_disconnect();
wifi_station_connect();
break;
case SC_STATUS_LINK_OVER:
printf(“SC_STATUS_LINK_OVER\n”);
if (pdata != NULL) {
//SC_TYPE_ESPTOUCH
uint8 phone_ip[4] = { 0 };memcpy(phone_ip, (uint8*)pdata, 4);
printf(“Phone ip: %d.%d.%d.%d\n”, phone_ip[0], phone_ip[1], phone_ip[2], phone_ip[3]);
break;
else {
//SC_TYPE_AIRKISS – support airkiss v2.0
//airkiss_start_discover();
smartconfig_stop();
break;
static void ICACHE_FLASH_ATTR
smartconfig_task(void *pvParameters)
smartconfig_start(smartconfig_done);vTaskDelete(NULL);
}//Unless you explicitly define the functions as RAMFUNC, they will be placed in the SPI FLASH and the debugger
//won’t be able to set software breakpoints there.
void RAMFUNC user_init(void)
gdbstub_init();
#error The LED on the Olimex board is multiplexed with the TXD line used by the GDB stub. In order to use the stub, select a different LED pin below.
#endif
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO4_U, FUNC_GPIO4);
printf(“SDK version:%s\n”, system_get_sdk_version());wifi_set_opmode(STATION_MODE);
xTaskCreate(LEDBlinkTask, (signed char *)”LEDBlinkTask”, 256, NULL, 2, NULL);
xTaskCreate(smartconfig_task, (signed char *)”smartconfig_task”, 256, NULL, 2, NULL);
This topic was modified 8 years, 8 months ago by
Yuex.S.
You must be logged in to view attached files.July 18, 2017 at 03:02 #11738Yuex.S
ParticipantThis is an example of the official website, do not understand why there is this error when writing.
July 18, 2017 at 03:15 #11739Yuex.S
Participant1>—— 已启动生成: 项目: 04SmartConfig, 配置: Debug VisualGDB ——
1> LEDBlink.c
1> Linking ../VisualGDB/Debug/04SmartConfig…
1>VisualGDB\Debug\LEDBlink.o : error : undefined reference to `smartconfig_stop’
1> VisualGDB/Debug/LEDBlink.o: In function `smartconfig_done’:
1>E:\Project\ESP8266\Project\04SmartConfig\04SmartConfig\LEDBlink.c(73): error : undefined reference to `smartconfig_stop’
1>E:\Project\ESP8266\Project\04SmartConfig\04SmartConfig\LEDBlink.c(78): error : undefined reference to `smartconfig_start’
1> VisualGDB/Debug/LEDBlink.o: In function `smartconfig_task’:
1>E:\Project\ESP8266\Project\04SmartConfig\04SmartConfig\LEDBlink.c(79): error : undefined reference to `smartconfig_start’
========== 生成: 成功 0 个,失败 1 个,最新 0 个,跳过 0 个 ==========July 18, 2017 at 05:47 #11744support
Looks like you are missing a reference to the libsmartconfig.a file. Please try adding it to your project (or adding “smartconfig” to the Library Names field in the Linker Settings).
December 13, 2017 at 01:16 #13258kostbill
ParticipantHello.
I am having the same problem. However I cannot find where this library is located, I searched my PC and it is not there. Also, when I find it, how am I going to add it to my project?
If I go to properties->Linker, what should I do next?
Thanks.
December 13, 2017 at 01:38 #13259kostbill
ParticipantOK, did it but I had to download the library from the net. It was not in my PC.
December 13, 2017 at 18:21 #13273support
Our ESP8266 toolchain only includes the libraries shipped with the RTOS and non-OS SDKs; if you want to use external libraries, you indeed need to download them (we recommend saving them outside the toolchain directory to avoid losing them during a toolchain update).
