Sysprogs forums › Forums › VisualGDB › ESP8266 and debugging with SEGGER j-link
- This topic has 1 reply, 2 voices, and was last updated 10 years, 3 months ago by
November 9, 2015 at 19:58 #7175
Dr.Nokill
ParticipantHello,
I’m trying to flash/debug an ESP8266 ESP-07 module with a 4 mbit flash. I use the FreeRTOS Webserver example, press debug and the following error is shown:
<pre style=”padding-left: 30px;”>C:\SysGCC\esp8266\python27\python.exe “C:\SysGCC\esp8266\esp8266-bsp\esptool.py” elf2image “C:\Users\DrNok\Documents\embedded\ESP8266\EmbeddedProject4\EmbeddedProject4/Debug/EmbeddedProject4.elf” –flash_freq 40m –flash_mode qio –flash_size 2m
mon reset halt
&”mon reset halt\n”
&”\”monitor\” command not supported by this target.\n”
^error,msg=”\”monitor\” command not supported by this target.”
-exec-next-instruction
001^done
^error,msg=”The program is not being run.”
set $com_sysprogs_esp8266_wdcfg=0
&”set $com_sysprogs_esp8266_wdcfg=0\n”
^done
set $vecbase=0x40000000
&”set $vecbase=0x40000000\n”
&”No registers.\n”
^error,msg=”No registers.”
set *(0x3fffc200)=0
&”set *(0x3fffc200)=0\n”
&”Cannot access memory at address 0x3fffc200\n”
^error,msg=”Cannot access memory at address 0x3fffc200″
set $ccompare=0
&”set $ccompare=0\n”
^done
set $intclear=-1
&”set $intclear=-1\n”
&”No registers.\n”
set $intenable=0
&”set $intenable=0\n”
&”No registers.\n”
print *((int *)0x60000900)
&”print *((int *)0x60000900)\n”
&”Cannot access memory at address 0x60000900\n”
^error,msg=”Cannot access memory at address 0x60000900″
set *((int *)0x60000900)=0
&”set *((int *)0x60000900)=0\n”
restore C:/SysGCC/esp8266/esp8266-bsp/sysprogs/flashprog/ESP8266FlashProg.bin binary 0x40100000 0 0x1a4
&”restore C:/SysGCC/esp8266/esp8266-bsp/sysprogs/flashprog/ESP8266FlashProg.bin binary 0x40100000 0 0x1a4\n”
&”You can’t do that without a process to debug.\n”
^error,msg=”You can’t do that without a process to debug.”
flushregs
&”flushregs\n”
~”Register cache flushed.\n”
^done
set $epc2=0x40100074
&”set $epc2=0x40100074\n”
&”No registers.\n”
set $ps=0x20
&”set $ps=0x20\n”
&”No registers.\n”
set $sp=0x3fffc000
&”set $sp=0x3fffc000\n”
&”No registers.\n”
set *((unsigned *)0x3fff8008)=0
&”set *((unsigned *)0x3fff8008)=0\n”
&”Cannot access memory at address 0x3fff8008\n”
^error,msg=”Cannot access memory at address 0x3fff8008″
set *((unsigned *)0x3fff800c)=4096
&”set *((unsigned *)0x3fff800c)=4096\n”
&”Cannot access memory at address 0x3fff800c\n”
^error,msg=”Cannot access memory at address 0x3fff800c”
set *((unsigned *)0x3fff8010)=4096
&”set *((unsigned *)0x3fff8010)=4096\n”
&”Cannot access memory at address 0x3fff8010\n”
^error,msg=”Cannot access memory at address 0x3fff8010″
set *((unsigned *)0x3fff8014)=4294967295
&”set *((unsigned *)0x3fff8014)=4294967295\n”
&”Cannot access memory at address 0x3fff8014\n”
^error,msg=”Cannot access memory at address 0x3fff8014″
set $intclear=-1
&”No registers.\n”
set $intenable=0
&”No registers.\n”
-exec-continue
-data-evaluate-expression “\*\(\(unsigned\ \*\)0x3fff8014\)”
mon reset halt
&”mon reset halt\n”
001^done
^done
&”No registers.\n”
set *(0x3fffc200)=0
set $ccompare=0
^done
set $intclear=-1
&”No registers.\n”
set $intenable=0
&”No registers.\n”
flushregs
&”flushregs\n”
^done
&”No registers.\n”
set $ps=0x20
&”set $ps=0x20\n”
&”No registers.\n”
set $sp=0x3fffc000
&”No registers.\n”
set $intclear=-1
&”No registers.\n”
set $intenable=0
&”No registers.\n”
-exec-continue
mon reset halt
&”mon reset halt\n”
001^done
^done
&”No registers.\n”
set *(0x3fffc200)=0
set $ccompare=0
^done
set $intclear=-1
&”No registers.\n”
set $intenable=0
&”No registers.\n”
flushregs
&”flushregs\n”
^done
&”No registers.\n”
set $ps=0x20
&”set $ps=0x20\n”
&”No registers.\n”
set $sp=0x3fffc000
&”No registers.\n”
set $intclear=-1
&”No registers.\n”
set $intenable=0
&”No registers.\n”
-exec-continue
Then another error Window is shown:
<pre style=”padding-left: 30px;”>(gdb begin)
VisualGDB is licensed to Martin Kunz
C:\SysGCC\esp8266\bin\xtensa-lx106-elf-gdb.exe –interpreter mi C:\Users\DrNok\Documents\embedded\ESP8266\EmbeddedProject4\EmbeddedProject4/Debug/EmbeddedProject4.elf
-list-features
=thread-group-added,id=”i1″
~”GNU gdb (GDB) 7.5.1\n”
~”Copyright (C) 2012 Free Software Foundation, Inc.\n”
~”This GDB was configured as \”–host=i686-pc-mingw32 –target=xtensa-lx106-elf\”.\nFor bug reporting instructions, please see:\n”
~”<http://www.gnu.org/software/gdb/bugs/>…\n”
~”Reading symbols from C:\\Users\\DrNok\\Documents\\embedded\\ESP8266\\EmbeddedProject4\\EmbeddedProject4\\Debug\\EmbeddedProject4.elf…”
~”done.\n”
^done,features=[“frozen-varobjs”,”pending-breakpoints”,”thread-info”,”data-read-memory-bytes”,”breakpoint-notifications”,”ada-task-info”]
^done
-gdb-set print demangle off
^done
-gdb-version
^done
-break-insert -f main
&”Function \”main\” not defined.\n”
-break-delete 1
^done
target remote :3333
&”target remote :3333\n”
&”:3333: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.\n”
^error,msg=”:3333: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.”
mon reset halt
&”mon reset halt\n”
001^done
^done
&”No registers.\n”
set *(0x3fffc200)=0
set $ccompare=0
^done
set $intclear=-1
&”No registers.\n”
set $intenable=0
&”No registers.\n”
flushregs
&”flushregs\n”
^done
&”No registers.\n”
set $ps=0x20
&”set $ps=0x20\n”
&”No registers.\n”
set $sp=0x3fffc000
&”No registers.\n”
set $intclear=-1
&”No registers.\n”
set $intenable=0
&”No registers.\n”
-exec-continue
mon reset halt
&”mon reset halt\n”
001^done
^done
&”No registers.\n”
set *(0x3fffc200)=0
set $ccompare=0
^done
set $intclear=-1
&”No registers.\n”
set $intenable=0
&”No registers.\n”
flushregs
&”flushregs\n”
^done
&”No registers.\n”
set $ps=0x20
&”set $ps=0x20\n”
&”No registers.\n”
set $sp=0x3fffc000
&”No registers.\n”
set $intclear=-1
&”No registers.\n”
set $intenable=0
&”No registers.\n”
-exec-continue
mon reset halt
&”mon reset halt\n”
001^done
^done
&”No registers.\n”
set *(0x3fffc200)=0
set $ccompare=0
^done
set $intclear=-1
&”No registers.\n”
set $intenable=0
&”No registers.\n”
flushregs
&”flushregs\n”
^done
&”No registers.\n”
set $ps=0x20
&”set $ps=0x20\n”
&”No registers.\n”
set $sp=0x3fffc000
&”No registers.\n”
set $intclear=-1
&”No registers.\n”
set $intenable=0
&”No registers.\n”
-exec-continue
mon xtensa_no_interrupts_during_steps on
&”mon xtensa_no_interrupts_during_steps on\n”
mon esp8266_autofeed_watchdog on
&”mon esp8266_autofeed_watchdog on\n”
info target
&”info target\n”
~”Symbols from \”C:\\Users\\DrNok\\Documents\\embedded\\ESP8266\\EmbeddedProject4\\EmbeddedProject4\\Debug\\EmbeddedProject4.elf\”.\n”
~”Local exec file:\n”
~”\t`C:\\Users\\DrNok\\Documents\\embedded\\ESP8266\\EmbeddedProject4\\EmbeddedProject4\\Debug\\EmbeddedProject4.elf’, file type elf32-xtensa-le.\n”
~”\tEntry point: 0x40100004\n”
~”\t0x3ffe8000 – 0x3ffe839a is .data\n”
~”\t0x3ffe83a0 – 0x3ffe867c is .rodata\n”
~”\t0x3ffe8680 – 0x3fff0148 is .bss\n”
~”\t0x40100000 – 0x40106555 is .text\n”
~”\t0x40240000 – 0x4027a5dd is .irom0.text\n”
^done
set *((int *)0x60000900)=$com_sysprogs_esp8266_wdcfg
&”set *((int *)0x60000900)=$com_sysprogs_esp8266_wdcfg\n”
-exec-continue
set $com_sysprogs_esp8266_wdcfg=*((int *)0x60000900)
— GDBServer output —
Open On-Chip Debugger 0.9.0 (2015-11-04-20:38)
<pre style=”padding-left: 30px;”>Licensed under GNU GPL v2
<pre style=”padding-left: 30px;”>For bug reports, read
<pre style=”padding-left: 30px;”> http://openocd.org/doc/doxygen/bugs.html
<pre style=”padding-left: 30px;”>trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst
<pre style=”padding-left: 30px;”>adapter speed: 1000 kHz
<pre style=”padding-left: 30px;”>stop_wdt
<pre style=”padding-left: 30px;”>Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
<pre style=”padding-left: 30px;”>Error: Cannot find jlink Interface! Please check connection and permissions.
When I try to debug again, the only the following error is shown:
<p style=”padding-left: 30px;”>am Files (x86)\Sysprogs\VisualGDB\vgagent.exe C:\SysGCC\esp8266\esp8266-bsp\openocd\bin\openocd.exe -f interface/jlink.cfg -f target/esp8266.cfg -c “adapter_khz 1000”
stop_wdt
Error: Cannot find jlink Interface! Please check connection and permissions.</p>
I tried a genuine j-link PRO and j-link EDU, when opening Visual GDB Project Properties -> Debug SettingsDebug Method: OpenOCD is selected. When clicking on Detect, “Detected Segger J-Link” is shown. When using the Arduino Toolchain the board works pretty well, power supply has enough output current. Both j-link work with STM32 cores without any problem. Does anyone have a tip what I’m doing wrong?
November 10, 2015 at 18:23 #7180support
OpenOCD needs a libusb-based driver for J-Link that is incompatible with the original J-Link driver. The easiest way to install it is using our USBDriverTool. You can also try configuring OpenOCD debugging with J-Link for an ARM project and click “Test settings” so that VisualGDB configures the driver automatically. We don’t have automatic driver setup for ESP8266 projects yet though.
