Hello. By default in ESP-PROG FTDI’s channel 0 is using as JTAG, when channel 1 is free and using as UART.
To use it as JTAG you must install WinUSB drivers on appropriate channgel. But in my case JTAG is workin only if both channels have WinUSB drivers.
By guide.
Debug using: OpenOCD
JTAG: Esp32 Devkit
If both FTDI channels (0 and 1) have WinUSB drivers – everything works as it should.
But if im trying to start debug when channel 1 drivers is standart USB-CDC – ive got next error:
Info : Listening on port 49591 for telnet connections
Error: type ‘esp32’ is missing virt2phys
Error: failed to reset FTDI device: LIBUSB_ERROR_PIPE
Error: unable to open ftdi device with vid 0403, pid 6010, description ‘*’, serial ‘*’ at bus location ‘*’
This topic was modified 6 years, 3 months ago by
Badang.
