ESP32: "Warning: could not set a breakpoint on main. 'Step into new instance' —
Sysprogs forums › Forums › VisualGDB › ESP32: "Warning: could not set a breakpoint on main. 'Step into new instance' —
  • #29963
    RolfSt
    I load my
    ESP-32 NodeMCU Developmantboard from AZ-Delivery via
    OLMEX ARM-SB-OCD-H
    and get
    Nevertheless, debgging seems to work. What does this warning mean ?
    I’m on the porting a STM32 app – done with VsualGDB – to ESP32 and try as a first step
    Blink as built in.
    Another question: should optimization set be set to -Og ?
    #29966
    It looks like your technical support has expired. Please feel free to renew your support here and we will be happy to answer your questions.
    #29994
    RolfSt
    So now I have updated my license
    #29995
    Thanks for renewing your license.
    This message comes from the VisualGDB logic responsible for the “Step into new instance” command. It would normally set a breakpoint in main() and if you start debugging with F10 instead of F5, the program would stop once this breakpoint triggers.
    Because ESP32 programs use app_main() instead of main(), this functionality won’t work by default. You can easily change the name of the function via VisualGDB Project Properties -> Advanced GDB Settings, or simply ignore the message if you are not using the “Step into new instance” command.
