ESP32 Variable Watch during Debugging
Sysprogs forums › Forums › VisualGDB › ESP32 Variable Watch during Debugging
  • #10155
    aaquilina
    I am debugging the ESP32-WROOM-32 using a USB to MPSEE Serial Cable over the JTAG interface. When setting up the debug settings, under programming interface, I select to specify and interface script manually and for this I selected interface/ftdi/um232h.cfg.
    DebugSettings
    Once I created the project, I copied over the HTTP Client example from the ESP-IDF. I then run the code and manage to break at my breakpoint. When break occurs and I mouse over a variable, and the value is listed as <unavailable>. Is this normal for the ESP32? Or is this caused by the USB to JTAG converter that I’m using? If it’s the latter, would I be better off with an Olimex debugger such as the ARM-USB-OCD-H?
    Variable Value
    #10156
    This is a known limitation of the ESP32 toolchain. To work around this, please wrap your function call with another one, e.g.:
    void ThreadBodyWrapper()
        ThreadBody();
    As long as the esp32 gdb can see the previous frame (ThreadBodyWrapper), it will be able to show the variable values in the current frame (ThreadBody).
