esp32 s3 jtag
Sysprogs forums › Forums › VisualGDB › esp32 s3 jtag
  • #32832
    engineering-spirit
    Is there support for the buildin usb JTAG of the esp32-s3 ?
    #32833
    engineering-spirit
    C:\Users\pvisser\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.esp32.core\bin\openocd.exe -c “gdb_port 64499” -c “telnet_port 64497” -f interface/esp_usb_jtag.cfg -c “adapter_khz 3000” -f target/esp32s3.cfg -c “echo VisualGDB_OpenOCD_Ready”
    Open On-Chip Debugger 0.10.0 (2022-05-03)
    Licensed under GNU GPL v2
    For bug reports, read
    Info : only one transport option; autoselect ‘jtag’
    Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
    Info : esp_usb_jtag: capabilities descriptor set to 0x2000
    adapter speed: 40000 kHz
    DEPRECATED! use ‘adapter speed’ not ‘adapter_khz’
    adapter speed: 3000 kHz
    Warn : Transport “jtag” was already selected
    Info : Listening on port 64497 for telnet connections
    Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND
    Error: esp_usb_jtag: could not find or open device!
    Error: No JTAG interface configured yet. Issue ‘init’ command in startup scripts before communicating with targets.
    Error: Failed to clear OCDDCR_ENABLEOCD!
    #32852
    engineering-spirit
    so the buildin jtag is not supported?
    Or is there a way to use it.
    I cant vind any option to use it in the debug configuration.
    #32854
    We have just retested it with the ESP32-S3-BOX and it worked just fine. Please make sure you actually install the WinUSB driver for the “USB Composite device”  as VisualGDB suggests (you need to select “USB Devices” in the “Debug Using” field for VisualGDB to check the drivers).
    The default driver layout (separate serial port & debug nodes) appears to be incompatible with the current version of OpenOCD.
    #33478
    AshvajitP
    I am getting the issue, not able to use debug my ESP32-S3 in custom board. I have already flashed my code in S3, but I am not able to debug using built-in USB debug of ESP32-S3.
    I am getting this exception message:
    VisualGDB version: 5.6.104.4534
    System.Exception: esp_usb_jtag: could not find or open device!
    at VisualGDB.Common_GUI.WPF.DebugMethodTestWindow.ThrowTestFailedException()
    at VisualGDB.Common_GUI.WPF.DebugMethodTestWindow.TestThreadBody()
    trace=[VisualGDB.Common_GUI.WPF.DebugMethodTestWindow.ThrowTestFailedException:56, VisualGDB.Common_GUI.WPF.DebugMethodTestWindow.TestThreadBody:356]
    Test settings
    C:\Users\APRASAD\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.esp32.core\bin\openocd.exe -c “gdb_port 60858” -c “telnet_port 60856” -f interface/esp_usb_jtag.cfg -c “adapter_khz 3000” -f target/esp32s3.cfg -c “echo VisualGDB_OpenOCD_Ready”
    Info : Listening on port 60856 for telnet connections
    • This reply was modified 3 years, 10 months ago by AshvajitP. Reason: To add more details
    #33481
    This is something to check with Espressif, the maintainers of the ESP32 OpenOCD port. All VisualGDB does in this case is launch OpenOCD with the parameters you select.
    #33485
    AshvajitP
    I have found the issue and I am able to debug my ESP32-S3 now. It turns out that visual GDB was not able to change the driver of USB device. I had to do it manually using USB Driver Tool and is working now with earlier given commands.
    #34395
    orbitcoms
    I am also interested how to get the debugging working for the S3.
    Can the dual USB version modules be debugged in Visual Studio with Visual gdb? The board works with openocd and flash programming ok in VS Code.
    I notice in the “New Espressif sdk project” dialog there is only option to select ESP32C3 built-in jtag. Is this to be selected to set up S3 debugging as attached?
    #34410
    The built-in debugging interface was originally introduced in ESP32C3, hence VisualGDB calls it “ESP32C3 debug interface”. If it was auto-detected by the USB ID as shown on the screenshot, it should work just fine.
