ESP32 IDF Debugging Issues
Sysprogs forums › Forums › VisualGDB › ESP32 IDF Debugging Issues
  • #23256
    hf
    i’ve updated to the latest VisualGDB to run a test project with the ADF and IDF. But the Blinky demo did compile but fails on starting the debugger;
    this is the expection:
    VisualGDB version: 5.4.12.2657
    at qf..ctor(GDBSessionLaunchOptions a, el1 b)
    at el1..ctor(GDBSessionLaunchOptions a)
    at xx.a_2()
    at VisualGDB.GDBDebugEngine.b1(e41 a)
    at VisualGDB.GDBDebugEngine.Attach(IDebugProgram2[] b, IDebugProgramNode2[] d, UInt32 a, IDebugEventCallback2 c, enum_ATTACH_REASON e)
    #23262
    Thanks for reporting this. The problem might be caused by the fact that VisualGDB doesn’t support ADF out-of-the-box. Please try checking if the problem persists when debugging a regular ESP-IDF project.
    It also looks like your technical support period as expired. Please renew it here in order to keep on receiving technical support.
