Sysprogs forums › Forums › VisualGDB › ESP32 Debugging failed with Visual Studio due to FLASH programming
- This topic has 11 replies, 2 voices, and was last updated 3 years, 1 month ago by
February 8, 2023 at 02:41 #33825
lisa.tamanti@faacgroup.com
ParticipantI had a problem starting debug ESP32 with Visual studio: FLASH programming failed.
Until yesterday it was functioning…Debug Settings are:
Debug using: OpenOCD
JTAG/SWD programmer: ESP32 Devkit
Set JTAG/SWD frequency to 3000
Debugging devie: ESP32
Program FLASH memory: always
Program FLASH using OpenOCD(via JTAG)TEST debug is OK.
Logs from TEST DEBUG are:VisualGDB_OpenOCD_Ready
Info : Listening on port 54906 for telnet connections
Info : clock speed 3000 kHz
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Info : starting gdb server for esp32.cpu0 on 54908
Info : Listening on port 54908 for gdb connections
Info : accepting ‘gdb’ connection on tcp/54908
Info : esp32.cpu0: Target halted, PC=0x401EA6AE, debug_reason=00000000
Info : Set GDB target to ‘esp32.cpu0’
Info : esp32.cpu1: Target halted, PC=0x401EA6AE, debug_reason=00000000
Warn : No symbols for FreeRTOS!
Info : esp32.cpu0: Target halted, PC=0x4009260E, debug_reason=00000001
Error: Failed to get flash maps (4294967290)!
Warn : Failed to get flash mappings (-4)!
Info : Auto-detected flash bank ‘esp32.cpu0.flash’ size 16384 KB
Info : Using flash bank ‘esp32.cpu0.flash’ size 16384 KB
Info : Using flash bank ‘esp32.cpu0.irom’ size 0 KB
Info : Using flash bank ‘esp32.cpu0.drom’ size 0 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
Info : dropped ‘gdb’ connection
shutdown command invokedLogs from Visual Studio are:
@”JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)\n”
@”JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)\n”
@”esp32.cpu0: Target halted, PC=0x400803C0, debug_reason=00000001\n”
@”esp32.cpu0: Core was reset.\n”
@”esp32.cpu0: Target halted, PC=0x40000400, debug_reason=00000000\n”
@”esp32.cpu1: Core was reset.\n”
@”esp32.cpu1: Target halted, PC=0x40000400, debug_reason=00000000\n”
^done
mon program_esp “C:/Progetti_FW/FAAC_IOT_GIT/build/VisualGDB/Debug/bootloader/bootloader.bin” 0x1000
&”mon program_esp \”C:/Progetti_FW/FAAC_IOT_GIT/build/VisualGDB/Debug/bootloader/bootloader.bin\” 0x1000\n”
@”esp32.cpu0: Debug controller was reset.\n”
@”esp32.cpu0: Target halted, PC=0x500000CF, debug_reason=00000000\n”
@”esp32.cpu1: Debug controller was reset.\n”
@”timed out while waiting for target halted\n”
@”esp32.cpu0: Target halted, PC=0x4000C2DD, debug_reason=00000000\n”
@”xtensa_wait_algorithm: not halted 0, pc 0x4000c2dd, ps 0x60025\n”
@”Failed to wait algorithm (-302)!\n”
@”Algorithm run failed (-302)!\n”
@”Too many flash mappings 11072892! Must be 2.\n”
@”Failed to get flash mappings (-4)!\n”
@”Target is already running an algorithm\n”
@”Failed to start algorithm (-4)!\n”
@”Failed to get flash size!\n”
@”Failed to probe flash, size 0 KB\n”
@”auto_probe failed\n”
@”Failed to find bank ‘esp32.cpu1.flash’!\n”
@”\n”
^done
-target-disconnect
=thread-group-exited,id=”i1″
^done
-gdb-exit
^exitFebruary 8, 2023 at 09:38 #33829support
This looks like a known issue of the ESP32 OpenOCD. Please see this thread for details.
In order to flash the application via USB as the thread suggests, you can use the “Program FLASH Memory” command in the context menu in Solution Explorer (you would need the make sure the virtual COM port used for programming has the correct drivers installed).
February 8, 2023 at 23:09 #33830lisa.tamanti@faacgroup.com
ParticipantSorry, but I continue to have the problem also after to have programmed by USB – COM bootloader and partition table..
The problem was born after to have updated last Open OCD proposed on VisualStudio ….then I removed that Open OCD but the problem remained ..
February 9, 2023 at 00:09 #33831support
It could be a bug in a particular OpenOCD version then. You can always revert to the previous version as shown here: https://visualgdb.com/support/oldpackages/
Restoring the previous OpenOCD and doing a full FLASH erase via esptool.py should completely reverse any changes done by the newer OpenOCD.
February 9, 2023 at 01:33 #33832lisa.tamanti@faacgroup.com
ParticipantI restored the previus openOCD but I have the same problem 🙁
Is it possible to understand something from Error log below?
@”\n”
^done
-target-disconnect
^done
-gdb-exit
^exitFebruary 9, 2023 at 19:16 #33842support
The log comes from the OpenOCD tool, that is maintained by Espressif, so we do not have much insights into it. You can try downloading OpenOCD from Espressif directly, running it manually per their instructions, and checking if it works. If it fails with the same error, please consider posting on the Espressif’s forum, perhaps they have a better idea of what’s going on.
If OpenOCD works when running it manually, but doesn’t work with VisualGDB, please let us know and we will walk you through getting it to work with VisualGDB as well.
February 14, 2023 at 00:54 #33846lisa.tamanti@faacgroup.com
ParticipantEspressif forum told me that OpenOCD looses offset of my application that is necessary to give this information to OpenOCD with:
-c “init; halt; esp appimage_offset 0x20000”
But where and how in VisulStudio can I give to OpenOCD this information?
In the past this operation wasn’t necessary….
February 14, 2023 at 08:25 #33847support
It should normally not be necessary – in our tests OpenOCD managed to find everything automatically. Either way, please follow the steps below to resolve it:
- Try starting a debug session. Take a note of the OpenOCD command line at the beginning of the Debug->Windows->VisualGDB Output window.
- Try adding -c “esp appimage_offset 0x20000” at the end of the Command Line setting under VisualGDB Project Properties -> Debug Settings -> Advanced Settings (bottom of the page). You should not normally need the “init; halt” part.
- Try starting another debug session. Take a note of the updated command line in the VisualGDB Output window.
- If this does not resolve the problem, please try adding the “init; halt” part as well.
If the problem is resolved, please share the full command line so that we could look further into it and make sure VisualGDB handles it automatically.
February 15, 2023 at 23:46 #33855lisa.tamanti@faacgroup.com
ParticipantThis is my initial OpenOCD start command:
C:\Users\bope02\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.esp32.core\bin\openocd.exe -c “gdb_port 54033” -c “telnet_port 54031” -f interface/ftdi/esp32_devkitj_v1.cfg -c “adapter_khz 3000” -f target/esp32.cfg -c “echo VisualGDB_OpenOCD_Ready”
Open On-Chip Debugger 0.10.0 (2022-05-03)I’m sorry but after added the command line as you indicated (see attached file VisualGDB_Debug.jpg) when I start DEBUG immediately I always have an error “Target not halted”.
Even If I disconnect and then riconnect USB I continue to have this error.
In this case logs are:C:\Users\bope02\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.esp32.core\bin\openocd.exe -c “gdb_port 54450” -c “telnet_port 54448” -f interface/ftdi/esp32_devkitj_v1.cfg -c “adapter_khz 3000” -f target/esp32.cfg -c “esp appimage_offset 0x20000” -c “echo VisualGDB_OpenOCD_Ready”
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHzDEPRECATED! use ‘adapter speed’ not ‘adapter_khz’
adapter speed: 3000 kHzError: Target not halted
Then I tryed to add “init; halt” but without any result but with a different error message:
C:\Users\bope02\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.esp32.core\bin\openocd.exe -c “gdb_port 54502” -c “telnet_port 54500” -f interface/ftdi/esp32_devkitj_v1.cfg -c “adapter_khz 3000” -f target/esp32.cfg “init; halt” -c “esp appimage_offset 0x20000” -c “echo VisualGDB_OpenOCD_Ready”
Unexpected command line argument: “init;February 16, 2023 at 05:19 #33856support
Sorry for the confusion. The correct command line should be:
C:\Users\bope02\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.esp32.core\bin\openocd.exe -c “gdb_port 54502” -c “telnet_port 54500” -f interface/ftdi/esp32_devkitj_v1.cfg -c “adapter_khz 3000” -f target/esp32.cfg -c “init; halt;esp appimage_offset 0x20000” -c “echo VisualGDB_OpenOCD_Ready”
You can also do this:
-c init -c halt -c "esp appimage_offset 0x20000"
February 16, 2023 at 05:35 #33857lisa.tamanti@faacgroup.com
ParticipantON your previous message I see different gdb_port and telnet_port from mine….Have I to change ? Where I can change them?
February 16, 2023 at 05:39 #33858support
KeymasterIf you are changing the command line in VisualGDB project properties, rather than running VisualGDB manually, you do not need to specify the gdb port. Simply use -c “init; halt; esp appimage_offset 0x20000” instead of init; halt” -c “esp appimage_offset 0x20000” that you tried before. Please also make sure there is a space before -c.
