Sysprogs forums › Forums › VisualGDB › ESP32 Debugger not halting
- This topic has 3 replies, 2 voices, and was last updated 9 years, 7 months ago by
January 8, 2017 at 13:08 #9976
Frank
ParticipantHello,
I’m having trouble debugging my esp32 with visualgdb.
I am able to insert a breakpoint in my entry function app_main(), or functions called from app_main.
When I put a breakpoint in a task or in the event handler the cpu halts but visualgdb isn’t aware that the cpu has halted at that breakpoint and thinks its still running.
From the serial output I can see it has halted before executing the breakpoint line, and when I stop debugging and resume the program it continues from that point.Any suggestions?
January 8, 2017 at 17:48 #9978support
We have encountered similar behavior with ESP8266 – some firmware (specifically AT commands) triggered some undocumented hardware mode that prevented the breakpoints from being handled properly. Unfortunately this is something beyond our control so the only advice we could give here is to experiment with moving the functions to RAM and setting explicit breakpoints (asm(“break 1,1”)) in various functions to understand what triggers this mode.
January 9, 2017 at 13:32 #9991Frank
Participantit seems the breakpoint is being hit but the debugger resets.
This issue is caused by OpenOCD resetting the debug controller??GDB:
esp32.cpu0: Target halted, pc=0x401074B8 esp32.cpu0: Debug controller was reset (pwrstat=0xFC, after clear 0xFC). esp32.cpu0: Core was reset (pwrstat=0xFC, after clear 0xFC). esp32.cpu1: Debug controller was reset (pwrstat=0xFE, after clear 0xFE). esp32.cpu1: Core was reset (pwrstat=0xFE, after clear 0xFE).http://pastebin.com/fbiSrjRg for the full gdb output
OpenOCD:
Info : esp32.cpu0: Target halted, pc=0x401074B8 Warn : esp32.cpu1: target not halted Info : esp32.cpu1: Target halted, pc=0x40080340 esp32.cpu1: target state: halted Info : esp32.cpu1: placed hw breakpoint 0 at 0x401070FC Info : esp32.cpu0: placed hw breakpoint 0 at 0x401070FC Info : esp32.cpu0: Debug controller was reset (pwrstat=0xFC, after clear 0xFC). Info : esp32.cpu0: Core was reset (pwrstat=0xFC, after clear 0xFC). Info : esp32.cpu1: Debug controller was reset (pwrstat=0xFE, after clear 0xFE). Info : esp32.cpu1: Core was reset (pwrstat=0xFE, after clear 0xFE).http://pastebin.com/zdzytQCt for the full openocd output
January 10, 2017 at 03:38 #9999support
ESP32 has 3 different watchdogs that could be restarting the CPU once it is stopped and we experienced similar behavior before we modified the ESP32 OpenOCD to explicitly disable them:
xtensa_write_hwreg(target, 0x3FF5F064, 0x50d83aa1); //TIMG1 WDT xtensa_write_hwreg(target, 0x3FF5F048, 0); xtensa_write_hwreg(target, 0x3FF60064, 0x50d83aa1); //TIMG2 WDT xtensa_write_hwreg(target, 0x3FF60048, 0); xtensa_write_hwreg(target, 0x3ff480a4, 0x50d83aa1); //RTC WDT xtensa_write_hwreg(target, 0x3ff4808c, 0);
Our best guess is that in your case this mechanism does not work. Unfortunately the ESP32 tools are currently not very reliable and do not provide good troubleshooting mechanisms, so the only advice we could give is to do some black box experiments to understand what triggers the problem.
