Sysprogs forums › Forums › VisualGDB › ESP32 ADF Configuration broken because of python
- This topic has 1 reply, 2 voices, and was last updated 3 years, 5 months ago by
February 2, 2023 at 16:50 #33778
felixcollins
ParticipantI broke my ESP32 ADF project setup by accidentally installing the offered ESP tools update (not compatible with ADF so I rolled it back). I’ve uninstalled all the python installs I can find on the system. I’ve tried manually setting IDF_PYTHON_ENV_PATH in the cmake env settings for the project but that does not seem to help much.
What steps should I take to cure this issue and get my project building again?
Cheers,
Felix
Running CMake: C:\Users\felix\AppData\Local\VisualGDB\CMake\bin\cmake.exe ../../.. -G “Ninja” -DCMAKE_BUILD_TYPE=DEBUG -DCMAKE_MAKE_PROGRAM=”C:/Program Files (x86)/Sysprogs/VisualGDB/ninja.exe” -DESP_PLATFORM=1 -DCCACHE_ENABLE=1 -DIDF_TARGET=esp32
— ccache will be used for faster recompilation
— Building ESP-IDF components for target esp32
— Checking Python dependencies…
The following Python requirements are not satisfied:
pyparsing>=2.0.3,<2.4.0
idf-component-manager~=1.0
gdbgui==0.13.2.0
pygdbmi<=0.9.0.2
python-socketio<5
itsdangerous<2.1
kconfiglib==13.7.1
reedsolo>=1.5.3,<=1.5.4
bitstring>=3.1.6
ecdsa>=0.16.0
construct==2.10.54
esp-windows-curses; sys_platform == ‘win32’
Please follow the instructions found in the “Set up the tools” section of ESP-IDF Getting Started Guide
Diagnostic information:
IDF_PYTHON_ENV_PATH: (not set)
Python interpreter used: C:\Users\felix\AppData\Local\VisualGDB\Python3\python.exe
Warning: python interpreter not running from IDF_PYTHON_ENV_PATH
PATH: C:\Program Files\Git\cmd;C:\Users\felix\AppData\Local\VisualGDB\Python3;C:\SysGCC\esp32\tools\xtensa-esp32-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32-elf\bin;C:\SysGCC\esp32\tools\xtensa-esp32-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32-elf\bin;C:\SysGCC\esp32\tools\xtensa-esp32s2-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32s2-elf\bin;C:\SysGCC\esp32\tools\xtensa-esp32s3-elf\esp-2021r2-patch5-8.4.0\xtensa-esp32s3-elf\bin;C:\SysGCC\esp32\tools\esp32ulp-elf\2.35_20220830\esp32ulp-elf\bin;C:\SysGCC\esp32\tools\riscv32-esp-elf\esp-2021r2-patch5-8.4.0\riscv32-esp-elf\bin;C:\SysGCC\esp32\tools\idf-exe\1.0.3;C:\SysGCC\esp32\tools\ccache\4.3\ccache-4.3-windows-64;C:\SysGCC\esp32\tools\ninja\1.10.2;C:\SysGCC\esp32\tools\mconf-idf;C:\Python310\Scripts\;C:\Python310\;C:\Program Files\Eclipse Foundation\jdk-8.0.302.8-hotspot\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\include;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\extras\CUPTI\libx64;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.0\libnvvp;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\extras\CUPTI\libx64;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\bin;C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\libnvvp;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\140\Tools\Binn\;C:\Program Files\Microsoft SQL Server\140\Tools\Binn\;C:\Program Files\Microsoft SQL Server\140\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\150\DTS\Binn\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files\PuTTY\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\Nsight Compute 2019.4.0\;C:\flutter\bin;C:\Program Files\Android\Android Studio\jre\bin;C:\Users\felix\AppData\Local\Android\Sdk\platform-tools;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\Docker\Docker\resources\bin;C:\ProgramData\DockerDesktop\version-bin;C:\Program Files\Git\cmd;C:\ProgramData\chocolatey\bin;C:\MinGW\bin;C:\Program Files\nodejs\;C:\Program Files\dotnet\;C:\Users\felix\AppData\Local\Microsoft\WindowsApps;C:\Users\felix\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\felix\.dotnet\tools;C:\Users\felix\AppData\Local\Microsoft\WindowsApps;C:\Users\felix\AppData\Roaming\Pub\Cache\bin;C:\Users\felix\AppData\Local\GitHubDesktop\bin;C:\Users\felix\AppData\Roaming\npm;C:\Users\felix\.dotnet\tools
— Configuring incomplete, errors occurred!
See also “C:/Users/felix/source/beakbox/Firmware/beakbox3/build/VisualGDB/Debug/CMakeFiles/CMakeOutput.log”.
CMake Error at C:/SysGCC/esp32/esp-adf/v2.4/esp-idf/tools/cmake/build.cmake:287 (message):
Some Python dependencies must be installed. Check above message for
details.
C:/SysGCC/esp32/esp-adf/v2.4/esp-idf/tools/cmake/build.cmake:416 (__build_check_python)
C:/SysGCC/esp32/esp-adf/v2.4/esp-idf/tools/cmake/project.cmake:384 (idf_build_process)
CMakeLists.txt:9 (project)System.Exception: CMake exited with code 1
at dg.b(d b, Object a)========== Project Configuration Summary ==========
beakbox3 configured in 00:09
========== Configuration: 1 Succeeded, 0 Failed, 0 Skipped ==========February 2, 2023 at 17:21 #33779support
