Error in finding atomic_load_8
Sysprogs forums › Forums › VisualGDB › Error in finding atomic_load_8
  • #26120
    AndrewMoss
    Hi there,
    I am following the https://visualgdb.com/tutorials/raspberry/opencv/build/ tutorial to cross compile to a raspberry pi. I am using Open CV 4.1.1. and Visual Studio 19.  I get to step 13 and I get these errors showing up. Can anyone let me know what to do to remedy the errors?
    Error undefined reference to `__atomic_load_8' LinuxProject1 c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/8/../../../../arm-linux-gnueabihf/bin/ld.exe: ../../lib/libopencv_core.so.4.1.1
    Severity Code Description Project File Line Suppression StateError undefined reference to `__atomic_fetch_add_8' LinuxProject1 c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/8/../../../../arm-linux-gnueabihf/bin/ld.exe: ../../lib/libopencv_core.so.4.1.1
    Error undefined reference to `__atomic_compare_exchange_8' LinuxProject1 c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/8/../../../../arm-linux-gnueabihf/bin/ld.exe: ../../lib/libopencv_core.so.4.1.1
    Error undefined reference to `__atomic_store_8' LinuxProject1 c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/8/../../../../arm-linux-gnueabihf/bin/ld.exe: ../../lib/libopencv_core.so.4.1.1
    Error undefined reference to `__atomic_fetch_sub_8' LinuxProject1 c:/sysgcc/raspberry/bin/../lib/gcc/arm-linux-gnueabihf/8/../../../../arm-linux-gnueabihf/bin/ld.exe: ../../lib/libopencv_core.so.4.1.1
    Andrew
    • This topic was modified 6 years, 11 months ago by support. Reason: formatting
    #26122
    This looks like some sort of incompatibility between a specific version of the toolchain and a specific version of OpenCV.
    Unfortunately, as both components are outside of our control, we are not able to cover this with our regular technical support, so our best advice would be to try asking on the OpenCV forums if anyone has encountered similar errors before.
