Sysprogs forums › Forums › Other tools & products › Error building my own toolchain
- This topic has 11 replies, 3 voices, and was last updated 12 years, 7 months ago by
ket.
August 16, 2013 at 15:53 #624
Sgalperin
ParticipantI have been trying to follow the “Building You Own GNU Toolchain” example and I’m getting an error that I don’t understand.
I installed MinGW and Msys per the instructions. Then I downloaded binutils-2.23.0 from the GNU archive. I created the directories and did the configure and make commands per the tutorial, and I get the following error:
checking whether to build shared libraries… yes
checking whether to build static libraries… yes
checking how to run the C++ preprocessor… /lib/cpp
configure: error: in `/c/gnu/binutils-2.23.0-build/ld’:
configure: error: C++ preprocessor “/lib/cpp” fails sanity check
See `config.log’ for more details.
make[1]: *** [configure-ld] Error 1
make[1]: Leaving directory `/c/gnu/binutils-2.23.0-build’
make: *** [all] Error 2config.log has the following:
configure:4616: $? = 0
configure:4605: g++ -v >&5
Using built-in specs.
COLLECT_GCC=c:SysGCCpowerpc-eabipowerpc-eabibing++.exe
Target: powerpc-eabi
Configured with: ../gcc-4.8.0/configure –target powerpc-eabi –enable-win32-registry=SysGCC-powerpc-eabi-4.8.0 –prefix /q/gnu/auto/bu-2.23.1+gcc-4.8.0+gmp-4.2.4+mpfr-2.4.1+mpc-0.8+newlib-2.0.0-powerpc-eabi/ –enable-languages=c,c++ –disable-nls –disable-shared –with-newlib –with-headers=../newlib-2.0.0/newlib/libc/include –enable-interwork –enable-multilib –with-float=soft : (reconfigured) ../gcc-4.8.0/configure –target powerpc-eabi –enable-win32-registry=SysGCC-powerpc-eabi-4.8.0 –prefix /q/gnu/auto/bu-2.23.1+gcc-4.8.0+gmp-4.2.4+mpfr-2.4.1+mpc-0.8+newlib-2.0.0-powerpc-eabi/ –enable-languages=c,c++ –disable-nls –disable-shared –with-newlib –with-headers=../newlib-2.0.0/newlib/libc/include –enable-interwork –enable-multilib –with-float=soft
Thread model: single
gcc version 4.8.0 (GCC)
configure:4605: g++ -V >&5
g++.exe: error: unrecognized command line option ‘-V’
g++.exe: fatal error: no input files
compilation terminated.
configure:4616: $? = 1
configure:4605: g++ -qversion >&5
g++.exe: error: unrecognized command line option ‘-qversion’
configure:4620: checking whether we are using the GNU C++ compiler
configure:4639: g++ -c conftest.cpp >&5
g++.exe: error: CreateProcess: No such file or directory
configure:4639: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME “”
| #define PACKAGE_TARNAME “”
| #define PACKAGE_VERSION “”
| #define PACKAGE_STRING “”
| #define PACKAGE_BUGREPORT “”
| #define PACKAGE_URL “”
| /* end confdefs.h. */
| int
| main ()
| #ifndef __GNUC__
| choke me
| #endif
| return 0;
| }Any idea what this is about?
August 16, 2013 at 17:46 #2584ket
The problem lies here:
You should be using the MinGW’s gcc to build the cross-toolchain as you are trying to build a cross-toolchain that will be run on Windows not on PowerPC. Furthermore, make sure that there are no other gnu toolchains on the PATH that could confuse the build process. Do not forget to set the target to powerpc-wrs-vxworks instead of arm-eabi as in the example.
August 19, 2013 at 12:34 #2586Sgalperin
ParticipantHow does COLLECT_GCC get set?
August 19, 2013 at 15:53 #2585ket
Check that there are no other GNU toolchain directories defined on the PATH variable. Make sure to build the toolchain from within MinGW shell.
August 21, 2013 at 11:42 #2587Sgalperin
ParticipantOK, got all the extraneous compilers out of the path, including cc.exe in the MinGWbin directory.
Now it’s asking for GMP, MPFR and MPC. I’m assuming that they need the same style directory structure that I used for binuitls and gcc. However they don’t take the –target option on configure. Any suggestions?
August 21, 2013 at 16:54 #2588ket
Simply extract those libraries to the respective GMP, MPFR and MPC directories under the built gcc directory. GCC will then configure and build them automatically as a part of its own build process.
August 22, 2013 at 16:46 #2589Sgalperin
ParticipantOK. I have everything downloaded and put in directories as advised by the folks at GNU. When make goes into the ./libcpp directory it errors out. Here is the display:
configure: loading cache ./config.cache
checking build system type… i686-pc-mingw32
checking host system type… i686-pc-mingw32
checking target system type… powerpc-ibm-eabi
checking whether make sets $(MAKE)… yes
checking for a BSD-compatible install… /bin/install -c
checking for i686-pc-mingw32-gcc… gcc
checking for C compiler default output file name… a.exe
checking whether the C compiler works… yes
checking whether we are cross compiling… no
checking for suffix of executables… .exe
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ISO C89… none needed
checking whether we are using the GNU C++ compiler… no
checking whether g++ accepts -g… no
checking for i686-pc-mingw32-ranlib… ranlib
checking how to run the C preprocessor… gcc -E
checking for grep that handles long lines and -e… /bin/grep
checking for egrep… /bin/grep -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking minix/config.h usability… no
checking minix/config.h presence… no
checking for minix/config.h… no
checking whether it is safe to define __EXTENSIONS__… yes
checking for special C compiler options needed for large files… no
checking for _FILE_OFFSET_BITS value needed for large files… unknown
checking for _LARGE_FILES value needed for large files… unknown
checking for aclocal… no
checking for autoconf… no
checking for autoheader… no
checking whether gcc supports -W… yes
checking whether gcc supports -Wall… yes
checking whether gcc supports -Wnarrowing… no
checking whether gcc supports -Wwrite-strings… yes
checking whether gcc supports -Wmissing-format-attribute… yes
checking whether gcc supports -Wstrict-prototypes… yes
checking whether gcc supports -Wmissing-prototypes… yes
checking whether gcc supports -Wold-style-definition… yes
checking whether gcc supports -Wc++-compat… yes
checking whether gcc supports -pedantic -Wlong-long… yes
checking whether gcc supports -fno-exceptions… yes
checking whether gcc supports -fno-rtti… yes
configure: error: C++ compiler missing or inoperational
make[1]: *** [configure-libcpp] Error 1
make[1]: Leaving directory `/c/gnu/gcc-4.8.1-build’
make: *** [all] Error 2August 22, 2013 at 18:50 #2590ket
Look into config.log for the exact cause of the error. The compiler is probably complaining about missing headers, you need to copy the system headers from your vxworks powerpc target to either sysrootusrinclude if you are using sysroot or
include if not. The location depends on how it is done for vxworks powerpc. August 23, 2013 at 14:11 #2593Sgalperin
ParticipantThe source of the error appears to be in the build for the std lib. It’s looking for g++ as a compiler which isn’t in the MinGW distribution.
From config.log in the libcpp directory:
configure:4850: result: yes
configure:4901: g++ -c conftest.cpp >&5
/c/gnu/gcc-4.8.1/libcpp/configure: line 1495: g++: command not found
configure:4901: $? = 127
configure: failed program was:August 25, 2013 at 03:07 #2591support
Please reinstall MinGW selecting “C++ compiler” in the installer options. Alternatively you can use a prebuilt package from http://gnutoolchains.com/mingw32/
August 27, 2013 at 16:29 #2592Sgalperin
ParticipantThe C++ installation got me farther than ever, the build took over 2 hours to fail. Now it’s missing stdio.h.
/c/gnu/gcc-4.8.1-build/./gcc/xgcc -B/c/gnu/gcc-4.8.1-build/./gcc/ -B/c/gnu/out/powerpc-ibm-eabi/bin/ -B/c/gnu/out/powerpc-ibm-ea
bi/lib/ -isystem /c/gnu/out/powerpc-ibm-eabi/include -isystem /c/gnu/out/powerpc-ibm-eabi/sys-include -g -O2 -msoft-float -mr
elocatable-lib -mno-eabi -mstrict-align -O2 -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -W -Wall -Wwrite-strings -Wcast-qual –
Wstrict-prototypes -Wmissing-prototypes -Wold-style-definition -isystem ./include -g -DIN_LIBGCC2 -fbuilding-libgcc -fno-stac
k-protector -I. -I. -I../../.././gcc -I../../../../gcc-4.8.1/libgcc -I../../../../gcc-4.8.1/libgcc/. -I../../../../gcc-4.8.1/l
ibgcc/../gcc -I../../../../gcc-4.8.1/libgcc/../include -o _muldi3.o -MT _muldi3.o -MD -MP -MF _muldi3.dep -DL_muldi3 -c ../..
/../../gcc-4.8.1/libgcc/libgcc2.c -fvisibility=hidden -DHIDE_EXPORTS
In file included from ../../../../gcc-4.8.1/libgcc/libgcc2.c:27:0:
../../../../gcc-4.8.1/libgcc/../gcc/tsystem.h:87:19: fatal error: stdio.h: No such file or directory
#include
make[4]: *** [_muldi3.o] Error 1
make[4]: Leaving directory `/c/gnu/gcc-4.8.1-build/powerpc-ibm-eabi/nof/libgcc’
make[3]: *** [multi-do] Error 1August 27, 2013 at 22:19 #2594ket
Is stdio.h provided by vxworks? If yes, have you copied the system headers over from vxworks as instructed before?
