Sysprogs forums › Forums › VisualGDB › Embedded Memory Explorer Name Demangling Fails
- This topic has 8 replies, 2 voices, and was last updated 2 months, 2 weeks ago by
January 9, 2026 at 10:05 #37048
Dan712
ParticipantEmbedded Memory Explorer fails to Demangle some template names. I believe this may have to do with providing a class literal as a template type(C++20). arm-none-eabi-c++filt.exe in the GCC 14.2.1 toolchain properly decodes the following example Embedded Memory Explorer fails on:
_ZN3utl9SingletonIN3tsk18StaticFreeRTOSTaskIN9KeypadMCU11DevCtlrTaskELNS1_7Stack_tE512ELb0EEEXtlNS_13StringLiteralILj5EEEtlA5_cLc46ELc98ELc115ELc115EEEELh0EXtlNS_23StringLiteralUninferredILj100EEEtlA100_cLc118ELc105ELc114ELc116ELc117ELc97ELc108ELc32ELc118ELc111ELc105ELc100ELc32ELc75ELc101ELc121ELc112ELc97ELc100ELc77ELc67ELc85ELc58ELc58ELc75ELc101ELc121ELc112ELc97ELc100ELc66ELc111ELc111ELc116ELc84ELc97ELc115ELc107ELc58ELc58ELc112ELc111ELc115ELc116ELc66ELc111ELc111ELc116ELc73ELc110ELc105ELc116ELc40ELc41EEEEEnwEjas
utl::Singleton<tsk::StaticFreeRTOSTask<KeypadMCU::DevCtlrTask, (tsk::Stack_t)512, false>, utl::StringLiteral<5u>{char [5]{(char)46, (char)98, (char)115, (char)115}}, (unsigned char)0, utl::StringLiteralUninferred<100u>{char [100]{(char)118, (char)105, (char)114, (char)116, (char)117, (char)97, (char)108, (char)32, (char)118, (char)111, (char)105, (char)100, (char)32, (char)75, (char)101, (char)121, (char)112, (char)97, (char)100, (char)77, (char)67, (char)85, (char)58, (char)58, (char)75, (char)101, (char)121, (char)112, (char)97, (char)100, (char)66, (char)111, (char)111, (char)116, (char)84, (char)97, (char)115, (char)107, (char)58, (char)58, (char)112, (char)111, (char)115, (char)116, (char)66, (char)111, (char)111, (char)116, (char)73, (char)110, (char)105, (char)116, (char)40, (char)41}}>::operator new(unsigned int)
Could Sysprog either fix this or provide a way to plugin custom demanglers? A plugin method would be welcome as then the char arrays could be displayed as strings.
January 9, 2026 at 10:21 #37049support
No problem, the demangler is already a separate DLL with a very simple interface (demangle.dll/demangle64.dll).
#include <cxxabi.h> #include <stdlib.h> extern "C" char *__declspec(dllexport) DemangleCXXName2(const char *pName) { int status = -1; return abi::__cxa_demangle(pName, 0, 0, &status); } extern "C" void __declspec(dllexport) FreeDemangledCXXName(char *pName) { free(pName); }You can build with MinGW using the following command line:
g++.exe demangle.cpp -o demangle.dll -shared -static-libgcc -static-libstdc++
We will update the version shipped with VisualGDB based on the latest MinGW toolchain in the final v6.1 release.
January 12, 2026 at 15:39 #37052Dan712
ParticipantThanks, recompiling that code fixed a bunch of the failures (after I remembered to pass -static-libgcc -static-libstdc++ to the linker as well). A couple did remain though, possibly because I was using the Sysprogs MinGW toolchains which are a couple gcc versions behind the arm-eabi gcc version(although binutil c++filt worked fine on both)
January 16, 2026 at 09:36 #37060support
KeymasterOK, we have rebuilt the demangler DLL based on GCC 15.2, and also updated our MinGW toolchains based on that version.
Feel free to try this build: VisualGDB-6.1.101.5494.msi
January 19, 2026 at 10:10 #37069Dan712
ParticipantThanks for the updated version. Unfortunately this doesn’t seem to fix the remaining bugs. On reinspection the remaining failures are inherited constructors from using declarations. Other methods and data members demangle properly.
January 19, 2026 at 10:35 #37070support
KeymasterNo problem. Could you please check whether it works with the c++filt.exe executable from our latest MinGW toolchain?
If not, does it work with any other c++filt version?
January 19, 2026 at 10:51 #37071Dan712
ParticipantI’ve checked with both MinGW and the toolchain I compiled it on and both c++filt fail. I may have gone too far with template hacks.
For reference the mangled name:
_ZN3utl9SingletonIN3tsk18StaticFreeRTOSTaskI14UtilMcuLtiTaskLNS1_7Stack_tE1536ELb0EEEXtlNS_13StringLiteralILj5EEEtlA5_cLc46ELc98ELc115ELc115EEEELh0EXtlNS_23StringLiteralUninferredILj100EEEtlA100_cLc85ELc116ELc105ELc108ELc77ELc99ELc117ELc76ELc116ELc105ELc67ELc111ELc110ELc102ELc105ELc103ELc58ELc58ELc85ELc116ELc105ELc108ELc77ELc99ELc117ELc76ELc116ELc105ELc67ELc111ELc110ELc102ELc105ELc103ELc40ELc104ELc100ELc58ELc58ELc73ELc50ELc99ELc66ELc117ELc115ELc88ELc102ELc101ELc114ELc77ELc101ELc100ELc105ELc117ELc109ELc42ELc44ELc32ELc104ELc100ELc58ELc58ELc73ELc50ELc99ELc66ELc117ELc115ELc88ELc102ELc101ELc114ELc77ELc101ELc100ELc105ELc117ELc109ELc42ELc41EEEEECI2S5_IJRN2hc6INA231ESG_SG_SG_SG_SG_RNSE_7BQ25790ESI_EEEPKcNS1_10Priority_tEDpOT_
January 19, 2026 at 10:54 #37072Dan712
ParticipantThis now seems outside of VisualGDB scope, thanks for the help.
January 20, 2026 at 08:07 #37077support
KeymasterNo problem. In our experience the GNU demangler is a few GCC releases behind the GCC itself. So, there’s a good chance that it will work better with GCC 16.0 or 17.0. You can try checking c++filt whenever a new GCC release comes out, and if it works better, we can easily rebuild our demangler using the same gcc version.
