dropped 'gdb' connection (error -400)
Sysprogs forums Forums VisualGDB dropped 'gdb' connection (error -400)
  • #22354
    matiase
    I create project according to this tutorial https://visualgdb.com/tutorials/arm/stm32/nucleo411re/.
    I have pcb NUCLEO F103RB. When I try to upload sample HAL project I can’t connect with microcontroller.
    In the attachment I send screen from debugging settings.
    Logs from test debugging:
    C:\Users\MK\AppData\Local\VisualGDB\EmbeddedDebugPackages\com.sysprogs.arm.openocd\bin\openocd.exe -c “gdb_port 54462” -c “telnet_port 54463” -f interface/stlink-v2-1.cfg -f target/stm32f1x.cfg -c init -c “reset init” -c “echo VisualGDB_OpenOCD_Ready”
    Open On-Chip Debugger 0.10.0 (2018-05-24) [https://github.com/sysprogs/openocd]
    Licensed under GNU GPL v2
    For bug reports, read
    WARNING: interface/stlink-v2-1.cfg is deprecated, please switch to interface/stlink.cfg
    adapter speed: 1000 kHz
    adapter_nsrst_delay: 100
    none separate
    Info : Unable to match requested speed 1000 kHz, using 950 kHz
    Info : clock speed 950 kHz
    Info : STLINK v2 JTAG v28 API v2 SWIM v17 VID 0x0483 PID 0x374B
    Info : using stlink api v2
    Info : Target voltage: 3.265963
    Info : stm32f1x.cpu: hardware has 6 breakpoints, 4 watchpoints
    Info : Listening on port 54462 for gdb connections
    xPSR: 0x01000000 pc: 0xd0024282 msp: 0x4b044800
    Info : Listening on port 54463 for telnet connections
    Info : accepting ‘gdb’ connection on tcp/54462
    Info : device id = 0x20036410
    Info : flash size = 128kbytes
    Info : dropped ‘gdb’ connection (error -400)
    I tried change interface/stlink-v2-1.cfg to interface/stlink.cfg and speed from 1000 to 950 kHz, but I still have the same problem.
    • This topic was modified 7 years, 5 months ago by matiase.
    #22358
    The text you attached doesn’t contain any specific error message, so the problem may not be on the OpenOCD’s side.
    Please describe what exactly you are observing/expecting and also obtain and attach a gdb session log as described here so that we could see what is going on.
