Sysprogs forums › Forums › WinCDEmu › Driver installation timed out
- This topic has 20 replies, 4 voices, and was last updated 13 years, 3 months ago by
Anonymous.
April 24, 2010 at 07:03 #184
OliT
I have the problem that WinCDEmu is not working on my Windows 7 Ultimate (32-Bit). I had installed V3.1 one month ago and it worked perfectly. As I wanted to mount an ISO image yesterday it failed for unknown reasons (no new drive and no error indication). So I
- Uninstalled V 3.1, Rebooted[/*:2tyviaxp]
- Ran wcdcleanup, Rebooted[/*:2tyviaxp]
- Installed the latest V3.3.1, Rebooted[/*:2tyviaxp]
After this mounting an ISO image started the installation of a new device driver which timed out after 5 minutes with error 0x000005b4 which is just the error code for timeout (see the attached extract of setupapi.dev.log). One main difference of installed software on my system between the working state and the current state of failure is the installation of iTunes in the meantime which was already mentioned as a trouble maker in other threads.
Any ideas what might go wrong ?
>>> [Device Install (Hardware initiated) - BazisVirtualCDBusStandardDeviceVirtualCD_0000]
>>> Section start 2010/04/24 08:19:51.683
ump: Creating Install Process: DrvInst.exe 08:19:51.685
ndv: Retrieving device info...
ndv: Setting device parameters...
ndv: Searching Driver Store and Device Path...
dvi: {Build Driver List} 08:19:52.658
cpy: Policy is set to make all digital signatures equal.
dvi: Enumerating INFs from path list 'C:Windowsinf'
inf: Opened PNF: 'C:WindowsSystem32DriverStoreFileRepositorycdrom.inf_x86_neutral_db87d184bc84f910cdrom.inf' ([strings.0409])
dvi: Created Driver Node:
dvi: HardwareID - GenCdRom
dvi: InfName - C:WindowsSystem32DriverStoreFileRepositorycdrom.inf_x86_neutral_db87d184bc84f910cdrom.inf
dvi: DevDesc - CD-ROM Drive
dvi: DrvDesc - CD-ROM Drive
dvi: Provider - Microsoft
dvi: Mfg - (Standard CD-ROM drives)
dvi: ModelsSec - cdrom_device.NTx86
dvi: InstallSec - cdrom_install
dvi: ActualSec - cdrom_install
dvi: Rank - 0x00ff0000
dvi: Signer - Microsoft Windows
dvi: Signer Score - INBOX
dvi: DrvDate - 06/21/2006
dvi: Version - 6.1.7600.16385
dvi: {Build Driver List - exit(0x00000000)} 08:19:52.982
ndv: Selecting best match from Driver Store (including Device Path)...
dvi: {DIF_SELECTBESTCOMPATDRV} 08:19:52.985
dvi: Using exported function 'DvdClassInstaller' in module 'C:Windowssystem32storprop.dll'.
dvi: Class installer == storprop.dll,DvdClassInstaller
dvi: Using exported function 'StorageCoInstaller' in module 'C:Windowssystem32SysClass.Dll'.
dvi: CoInstaller 1 == SysClass.Dll,StorageCoInstaller
dvi: Using exported function 'CriticalDeviceCoInstaller' in module 'C:Windowssystem32SysClass.Dll'.
dvi: CoInstaller 2 == SysClass.Dll,CriticalDeviceCoInstaller
dvi: CoInstaller 1: Enter 08:19:53.013
dvi: CoInstaller 1: Exit
dvi: CoInstaller 2: Enter 08:19:53.016
dvi: CoInstaller 2: Exit
dvi: Class installer: Enter 08:19:53.019
dvi: Class installer: Exit
dvi: Default installer: Enter 08:19:53.022
dvi: {Select Best Driver}
dvi: Selected driver installs from section [cdrom_install] in 'c:windowssystem32driverstorefilerepositorycdrom.inf_x86_neutral_db87d184bc84f910cdrom.inf'.
dvi: {DIF_DESTROYPRIVATEDATA} 08:19:53.027
dvi: CoInstaller 1: Enter 08:19:53.029
dvi: CoInstaller 2: Enter 08:19:53.032
dvi: Class installer: Enter 08:19:53.035
dvi: Default installer: Enter 08:19:53.038
dvi: Default installer: Exit
dvi: {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 08:19:53.041
dvi: Set selected driver complete.
dvi: Selected:
dvi: Description - [CD-ROM Drive]
dvi: InfFile - [c:windowssystem32driverstorefilerepositorycdrom.inf_x86_neutral_db87d184bc84f910cdrom.inf]
dvi: Section - [cdrom_install]
dvi: Signer - [Microsoft Windows]
dvi: Rank - [0x00ff0000]
dvi: {Select Best Driver - exit(0x00000000)}
dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 08:19:53.056
inf: {SetupCopyOEMInf: C:WindowsINFcdrom.inf} 08:19:53.057
inf: {SetupCopyOEMInf exit (0x00000050)} 08:19:53.059
ndv: Driver selected, now performing install...
ndv: {Core Device Install} 08:19:53.068
inf: Opened INF: 'C:WindowsINFcdrom.inf' ([strings.0409])
inf: Saved PNF: 'C:WindowsINFcdrom.PNF' (Language = 0409)
inf: Opened PNF: 'C:WindowsINFcdrom.inf' ([strings.0409])
dvi: {DIF_ALLOW_INSTALL} 08:19:53.112
dvi: CoInstaller 1: Enter 08:19:53.123
dvi: CoInstaller 2: Enter 08:19:53.126
dvi: Class installer: Enter 08:19:53.129
dvi: Default installer: Enter 08:19:53.132
dvi: {DIF_ALLOW_INSTALL - exit(0xe000020e)} 08:19:53.135
ndv: Installing files...
dvi: {DIF_INSTALLDEVICEFILES} 08:19:53.139
dvi: CoInstaller 1: Enter 08:19:53.140
dvi: CoInstaller 2: Enter 08:19:53.143
dvi: Class installer: Enter 08:19:53.146
dvi: Default installer: Enter 08:19:53.149
dvi: {Install FILES}
inf: Opened PNF: 'c:windowssystem32driverstorefilerepositorycdrom.inf_x86_neutral_db87d184bc84f910cdrom.inf' ([strings.0409])
inf: {Install Inf Section [cdrom_install]}
inf: CopyFiles=cdrom_copyfiles (cdrom.inf line 92)
flq: CopyFiles from an inbox inf.
cpy: Open PnpLockdownPolicy: Err=2. This is OK. Use LockDownPolicyDefault
flq: QueueSingleCopy...
flq: Inf : 'c:windowssystem32driverstorefilerepositorycdrom.inf_x86_neutral_db87d184bc84f910cdrom.inf'
flq: SourceInf: 'c:windowssystem32driverstorefilerepositorycdrom.inf_x86_neutral_db87d184bc84f910cdrom.inf'
flq: SourceSection: [sourcedisksfiles]
flq: Source root path based on SourceInf
flq: SourceRootPath: 'C:WindowsSystem32DriverStoreFileRepositorycdrom.inf_x86_neutral_db87d184bc84f910'
flq: {FILE_QUEUE_COPY}
flq: CopyStyle - 0x09000000
flq: SourceRootPath - 'C:WindowsSystem32DriverStoreFileRepositorycdrom.inf_x86_neutral_db87d184bc84f910'
flq: SourceFilename - 'cdrom.sys'
flq: TargetDirectory- 'C:Windowssystem32DRIVERS'
flq: TargetFilename - 'cdrom.sys'
flq: SourceDesc - 'windows cd'
flq: {FILE_QUEUE_COPY exit(0x00000000)}
inf: {Install Inf Section [cdrom_install] exit (0x00000000)}
dvi: Processing co-installer registration section [cdrom_install.CoInstallers].
inf: {Install Inf Section [cdrom_install.CoInstallers]}
inf: {Install Inf Section [cdrom_install.CoInstallers] exit (0x00000000)}
dvi: Co-installers registered.
dvi: {Install INTERFACES}
dvi: Installing section [cdrom_install.Interfaces]
dvi: {Install INTERFACES exit 00000000}
dvi: {Install FILES exit (0x00000000)}
dvi: {DIF_INSTALLDEVICEFILES - exit(0x00000000)} 08:19:53.199
ndv: Pruning file queue...
dvi: {_SCAN_FILE_QUEUE}
flq: ScanQ flags=620
flq: SPQ_SCAN_PRUNE_COPY_QUEUE
flq: SPQ_SCAN_FILE_COMPARISON
flq: SPQ_SCAN_ACTIVATE_DRP
flq: ScanQ number of copy nodes=1
flq: File 'C:Windowssystem32DRIVERScdrom.sys' pruned from copy.
sig: Using catalog 'C:Windowssystem32CatRoot{F750E6C3-38EE-11D1-85E5-00C04FC295EE}Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~x86~~6.1.7600.16385.cat'.
cpy: DrpSetRegFileProt 'C:Windowssystem32DRIVERScdrom.sys' Status=0 Class=Inbox Windows protected
flq: ScanQ action=200 DoPruning=32
flq: ScanQ end Validity flags=620 CopyNodes=0
dvi: {_SCAN_FILE_QUEUE exit(0, 0x00000000)}
ndv: Committing file queue...
flq: {_commit_file_queue}
flq: CommitQ DelNodes=0 RenNodes=0 CopyNodes=0
flq: CommitQ early exit: No nodes are queued
flq: {_commit_file_queue exit OK}
ndv: Registering CoInstallers...
dvi: {DIF_REGISTER_COINSTALLERS} 08:19:53.285
dvi: CoInstaller 1: Enter 08:19:53.288
dvi: CoInstaller 2: Enter 08:19:53.290
dvi: Class installer: Enter 08:19:53.293
dvi: Default installer: Enter 08:19:53.296
dvi: {DIF_DESTROYPRIVATEDATA} 08:19:53.304
dvi: CoInstaller 1: Enter 08:19:53.305
dvi: CoInstaller 2: Enter 08:19:53.308
dvi: Class installer: Enter 08:19:53.311
dvi: Default installer: Enter 08:19:53.313
dvi: {DIF_DESTROYPRIVATEDATA - exit(0xe000020e)} 08:19:53.316
dvi: {DIF_REGISTER_COINSTALLERS - exit(0x00000000)} 08:19:53.320
ndv: Installing interfaces...
dvi: {DIF_INSTALLINTERFACES} 08:19:53.323
dvi: CoInstaller 1: Enter 08:19:53.331
dvi: CoInstaller 2: Enter 08:19:53.334
dvi: Class installer: Enter 08:19:53.337
dvi: Default installer: Enter 08:19:53.340
dvi: {DIF_INSTALLINTERFACES - exit(0x00000000)} 08:19:53.349
ndv: Installing device...
dvi: {DIF_INSTALLDEVICE} 08:19:53.352
dvi: CoInstaller 1: Enter 08:19:53.353
dvi: CoInstaller 2: Enter 08:19:53.358
dvi: Class installer: Enter 08:19:53.361
dvi: Default installer: Enter 08:19:53.364
dvi: {Install DEVICE}
dvi: Processing Registry/Property directives...
inf: {Install Inf Section [cdrom_install.Hw]}
inf: AddReg=nosync_addreg (cdrom.inf line 95)
inf: {Install Inf Section [cdrom_install.Hw] exit (0x00000000)}
dvi: {Writing Device Properties}
dvi: Provider name=Microsoft
dvi: DriverDate 06/21/2006
dvi: DriverVersion=6.1.7600.16385
dvi: Class name=CDROM
dvi: Manufacturer=(Standard CD-ROM drives)
dvi: Matching DeviceID=gencdrom
dvi: Strong Name=cdrom.inf:cdrom_device.NTx86:cdrom_install:6.1.7600.16385:gencdrom
dvi: {Writing Device Properties - Complete}
inf: {Install Inf Section [cdrom_install.Services]}
inf: AddService=cdrom,0x00000002,cdrom_ServiceInstallSection,cdrom_EventLog_InstallSection (cdrom.inf line 98)
inf: ServiceType=1 (cdrom.inf line 106)
inf: StartType=1 (cdrom.inf line 107)
inf: ErrorControl=1 (cdrom.inf line 108)
inf: ServiceBinary=C:Windowssystem32DRIVERScdrom.sys (cdrom.inf line 109)
inf: DisplayName="CD-ROM Driver" (cdrom.inf line 105)
inf: LoadOrderGroup="SCSI CDROM Class" (cdrom.inf line 110)
dvi: Add Service: Modified existing service 'cdrom'.
inf: AddReg=autorun_addreg (cdrom.inf line 111)
inf: AddReg=cdrom_EventLog_AddReg (cdrom.inf line 114)
inf: {Install Inf Section [cdrom_install.Services] exit(0x00000000)}
dvi: Updated reflected section names for: cdrom.inf
dvi: {Install DEVICE exit (0x00000000)}
dvi: Writing common driver property settings.
dvi: DriverDescription=CD-ROM Drive
dvi: DeviceDisplayName=CD-ROM Drive
dvi: Install Device: Restarting device. 08:19:53.947
ump: Server install process exited with code 0x000005b4 08:24:53.354
<<< Section end 2010/04/24 08:24:53.356
<<< [Exit status: FAILURE(0x000005b4)]
April 24, 2010 at 07:56 #1407support
KeymasterAs described in another topic, check for additional CD/DVD filter drivers:
Select “start->run” or press “Windows key + R key”, type “regedit”.
Go to HKEY_LOCAL_MACHINE -> SYSTEM -> CurrentControlSet -> Control -> Class
Press “Ctrl+F”, type “cdrom”, press ENTER.
Ensure that the “{4D36E965-E325-11CE-BFC1-08002BE10318}” class was selected on the left.
Carefully examine the values on the right. If anything like “UpperFilters”, “LowerFilters” or anything else containing the word “filter” appears there, please either post the values here, or make a screenshot of your regedit window.April 25, 2010 at 06:31 #1406OliT
ParticipantThank you for your quick reply and hints.
There is indeed an upper filter driver defined. It’s the GEARAspiWDM driver 2.2.0.1 of GEAR Software Inc. After renaming the registry key UpperFilters into _UpperFilters followed by a reboot WinCDEmu works again like charme. I know the above solution is just a hack as one can have several upper filter drivers, etc.
My initial assumption was right because this filter driver was installed together with the iTunes (Norton Ghost and Norton 360 also use this driver according to the GEAR Software Wiki).
Starting iTunes with the modified registry I get an error message box that burning/ripping CDs is no longer possible and I have to re-install iTunes. Thankfully the program continues to start after clicking OK. As I consider this apple software as a pain in the ass with all of the useless services running in background after installation and just use it to synchronize mp3s, apps, etc. I can live with this. Of course it would be great if WinCDEmu would be able to work even if this filter is installed.
April 25, 2010 at 08:00 #1408support
KeymasterTry installing the latest trial of GearDVD. The version of GearASPIWdm that comes with it does not conflict with WinCDEmu. Moreover, it the Gear installer “understands” that GearASPIWdm is also needed by iTunes, uninstalling the trial will still keep the latest version of the filter.
April 26, 2010 at 04:24 #1409OliT
ParticipantThe latest trial of GEAR DVD I can download is V 7.03 RC 19. This doesn’t seem to update the GEARAspiWDM to a newer version and all files installed for this application are from January 2007. Ther is also a Driver Update package which seemed quite promising but it also didn’t update the filter driver to a newer revision.
Do you know the required revision of the GEARAspiWDM to work with WinCDEmu ?
April 26, 2010 at 08:17 #1410support
KeymasterThat’s just brilliant. Apparently, the Gear installer (file was called Download GEARDVD703rc19 now.exe) installed the 32-bit filter driver (that was of course ignored on 64-bit Windows), but updated the “UpperFilters” key, making me believe that the driver was there. So, no “GearDVD over iTunes” recipe” will work, unfortunately 🙁
I’ll try to investigate the GEAR-related problems later and maybe add some workaround, but I cannot promise anything, as gear stuff seems to be a big buggy mess, and I don’t want to support CD/DVD burning/identification commands in WinCDEmu, as this may come out twice more complex than the current WinCDEmu code.June 5, 2010 at 10:38 #1411Anonymous
Participant@OliT wrote:
- Uninstalled V 3.1, Rebooted[/*:jrxg3gtz]
- Ran wcdcleanup, Rebooted[/*:jrxg3gtz]
- Installed the latest V3.3.1, Rebooted[/*:jrxg3gtz]
dvi: Selected:
June 5, 2010 at 10:40 #1412support
KeymasterThis is a well-known bug in version 3.1. Please install WinCDEmu 3.3
June 5, 2010 at 15:25 #1413buRRRNs
ParticipantSame here! I’m running windows 7 32bit. Device driver installation just times out. And my computer fails to shutdown or restart(i have to do a hard shutdown). Any help would be appreciated.
June 9, 2010 at 18:04 #1414Anonymous
ParticipantI install today for the first time the 3.3-1 version on my windows 7 home premium 32-bit and when i try to mount an image windows start the driver installation and after about 5 minutes it fail installation. Then poweroff is broken. Please solve this problem! Thank you!!!
June 9, 2010 at 18:52 #1415Anonymous
ParticipantI have the same problem of Yojimbo and buRRRNs. Please help me!
July 12, 2010 at 05:42 #1416Anonymous
ParticipantI had the same problems with 3.3 – installing driver times out, must do a hard power off to shut down, etc., and renaming the Upperfilters registry entry fixed it for me. I never use iTunes to write to disc, so I don’t care if the fix disables that functionality. I would recommend putting this solution on a help or FAQ page.
July 12, 2010 at 08:52 #1417support
KeymasterThis is related to poorly designed CDROM filters provided by 3rd-party software. Please search for GearASPIWdm on this forum.
August 12, 2011 at 13:44 #1418Anonymous
- Uninstalled V 3.1, Rebooted[/*:11uu5u2p]
- Ran wcdcleanup, Rebooted[/*:11uu5u2p]
- Installed the latest V3.3.1, Rebooted[/*:11uu5u2p]
dvi: Selected:
August 12, 2011 at 15:30 #1419support
KeymasterHi. FIrst of all, please use the latest version (3.6). If the problem persists, you’re welcome to post here.
