Driver installation procedure
Sysprogs forums Forums WinCDEmu Driver installation procedure
  • #545
    pigster
    I am trying to install the driver as part of my installer with no luck.
    When i try to install the driver through devcon i am asked to confirm installation of unsecure driver and the end up with Unknown device. When i try to use the same command, but before install wincdemu using its native installer and deleting the device (effectively just re-adding device using devcon with already installed driver) i receive success and all works.
    Also tried to install driver using dpinst and than adding device through devcon install with no luck (same result as with plain devcon).
    So there must be some difference in your installer and normal windows driver installation procedure (maybe some additional steps)?
    What is the correct procedure to get the driver installed correctly? Can you pleas provide some info?
    Thank you
    #2328
    Reten
    I have posted the same question:
    viewtopic.php?f=3&t=2445
    If basiz add a command line for install/uninstall driver in the portable version you can make everything you want. We discuss about that feature here:
    viewtopic.php?f=3&t=2439
    Anyway if you resolved this post the solution here
    #2326
    pigster
    Well, all the code to install /uninstall portable driver is in the sources so it would be quiet easy to use portable driver right away. The problem is, that i can’t use the portable driver, because it is highly unstable on Windows 7 64bit. Sometimes it works, sometimes it crashes (blue screen). The non-portable driver works without any problem on various machines i tried if installed correctly.
    The non-portable driver would be just fine for me, but the installation procedure is somehow tricky.
    One simple thing would help me and that would be the set of API calls, which is used in the installer to the the driver properly loaded.
    #2327
    Reten
    Only one man can answer to your question…
    I don’t have see any bluescreen with WinCdEmu portable ( Win 7 x64 ), anyway hope you can resolve πŸ˜‰
