disabling on-the-fly TAR mode
Sysprogs forums Forums VisualGDB disabling on-the-fly TAR mode
  • #6128
    seulater
    I received this error message when trying to compile for the Intel Edison.
    “File transfer errors detected. Try disabling on-the-fly TAR mode for this host in SSH Host Manager”
    1>------ Build started: Project: rtos, Configuration: Debug Win32 ------
    1>  VisualGDB: Sending 6 updated source files to build machine...
    1>VisualGDB : warning : tar: invalid option -- 'm'
    1>VisualGDB : warning : BusyBox v1.22.1 (2014-12-09 18:30:16 CET) multi-call binary.
    1>VisualGDB : warning : Usage: tar -[cxtZzJjahvO] [-X FILE] [-T FILE] [-f TARFILE] [-C DIR] [FILE]...
    1>EXEC : warning VGDB2002: File transfer errors detected. Try disabling on-the-fly TAR mode for this host in SSH Host Manager.
    1>VisualGDB : error : Source file transfer failed. If you want to build your project nonetheless, edit project properties to ignore transfer errors.
    1>C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.MakeFile.Targets(38,5): error MSB3073: The command ""C:\Program Files (x86)\Sysprogs\VisualGDB\\VisualGDB.exe" /build "C:\Users\jim\Documents\VisualGDB\Intel_Edison\RTOS\rtos\rtos\rtos.vcxproj" "/solution:C:\Users\jim\Documents\VisualGDB\Intel_Edison\RTOS\rtos\rtos.sln" "/config:Debug" "/platform:Win32"" exited with code 1.
    #6129
    Looks like the tar binary on the Edison board does not support all options needed by VisualGDB to transfer multiple files using tar. You can switch to the file-by-file mode via Tools->SSH Host Manager->(your SSH connection)->Edit->Transfer file groups using = File-by-file SCP.
