Disable pause on Main
Sysprogs forums › Forums › VisualGDB › Disable pause on Main
  • #29763
    curtis.hendrix
    This is on version 5.5R4 (build 3920).  I recently updated and now the debugger always pauses on main when starting a debugging session.  How can I make it not do that, so starting a debugging session just runs the firmware?
    #29764
    This behavior should not be different in VisualGDB 5.5R4. Please try checking the GDB Session window for messages explaining this behavior. If nothing helps, please try obtaining and attaching a gdb log as shown here.
    #29768
    curtis.hendrix
    Figured out the problem.  I had a breakpoint set in a file that had been renamed or moved, but it was still listed in the “Breakpoint” window.  I deleted that breakpoint and now everything is working like it should.
