Debugging HAL_CM4.S in Mbed with Nucleo411RE
Sysprogs forums Forums VisualGDB Debugging HAL_CM4.S in Mbed with Nucleo411RE
  • #11240
    steveh
    Hi-
    I’m trying to debug what is going on during a task switch in MBED RTOS.  I can’t set a break point anywhere in the HAL_CM4.S file.  What can I do to debug the task switch in the .S file?
    #11241
    Please double-check that the .S file is actually compiled with the -ggdb switch (so that gdb can get debugging information for it). If it does not help, please try repairing breakpoints via VisualGDB breakpoint repair button in the GDB Session window.
    #11246
    steveh
    Thanks!
    The breakpoints repair button fixed this.
