Sysprogs forums › Forums › VisualGDB › Debugging ESP8266
- This topic has 8 replies, 2 voices, and was last updated 10 years, 6 months ago by
September 22, 2015 at 18:25 #6954
mfkfx
ParticipantHello,
when I try to load your basic HTTP-Example (IoT) into my ESP, the program does never hit a breakpoint.
There is only a message in GDB-Window: “Warning: could not set a breakpoint on main. ‘Step into new instance’ will not work.”
When using a program without flash (-> RAM), everything is working as expected.
Can you help me?
September 22, 2015 at 22:30 #6955support
KeymasterWhich board are you using? What happens if you then unplug the board and plug it back? Does the new program start normally, the old program start normally, or does nothing happen at all?
September 23, 2015 at 12:21 #6964mfkfx
ParticipantI have the nodemcu devkit.
The board was not starting from Flash because I removed a low-resistive connection between GPIO15 and GND for testing purposes. Now i have inserted a 10k resistor, so the board will try starting from flash.
Unfortunately I have a new problem: Received a SIGTRAP: Trace/breakpoint trap.Can you help me with that?
Thank you very much!
September 23, 2015 at 13:25 #6965mfkfx
ParticipantSome additional Information: I am using a J-Link Edu as Debugging device. It makes no difference if I connect the ESPs reset Signal to nTRST (JTAG reset) or to RESET (System reset) of the J-Link.
September 23, 2015 at 19:39 #6966support
Does the correct firmware start now if you manually restart the board? I.e. does the program happen during debugging only or does the programming fail?
September 24, 2015 at 09:51 #6968mfkfx
ParticipantHello again,
it seems the program does not start from flash. When I create the HTTP example, it looks like the flash programming is finished and the error message is appearing when the debugging starts.
However, when I disconnect the debugger and reset the chip, no WLAN-AP does appear.Do I have to adapt the flash configuration parameters? What can I do to solve this?
Regards
September 25, 2015 at 04:38 #6970support
Yes, please try experimenting with the flash size, speed and mode. Unfortunately there is not much documentation available from Espressif, so it’s hard to say which exact settings will work with your board.
Was the board working before with VisualGDB? Does it work with the bootloader now? Some users reported that that some of the boards come with very low-quality SPI FLASH that dies after less than 10 rewrite cycles.
September 28, 2015 at 16:18 #7007mfkfx
changing flash mode from qio to dio did the job 🙂
One last question: Now I’m trying to send a simple text over UART.
I added the “Peripheral Drivers (IoT)” in Properties -> Frameworks. Why can’t I use os_printf(“hello”)?
There is a define is osapi.h:#define os_printf os_printf_plus
The error is: ‘os_printf_plus’ was not declared in this scope.
Do I have to add a library in Properties -> Makefile settings -> Library Directories ?
Regards
September 30, 2015 at 20:25 #7026 -
