debug curser goes backward on simple statement sequence
Sysprogs forums › Forums › VisualGDB › debug curser goes backward on simple statement sequence
  • #11751
    elinir2000
    Curser jumps around for no apparent reason, and with no particular order, do I miss any flags during compilation ?
    change the code and it suddenly OK.
    Eli
    #11755
    This is to be expected if your code is using any other optimization level than -O0 (if you are using ESP32, you need to set -O0 optimization for your source files while keeping -Og for the ESP-IDF sources due to bugs in ESP-IDF).
    #11767
    elinir2000
    Mine was simpler issue of building release instead of DRBUG in CMskefile
