Sysprogs forums › Forums › VisualGDB › Custom Template Exception
- This topic has 25 replies, 2 voices, and was last updated 8 years, 9 months ago by
November 19, 2017 at 20:49 #13019
This should normally be fixed by including the script in the template by adding it to the project before exporting it.
However previously you have mentioned that you cannot do this because the build system complains. Please provide us the details on any errors you encounter when you try to add the second script before exporting the template.
November 20, 2017 at 16:08 #13026sidprice
ParticipantI added the secondary linker script to my reference project and got the following output:
1>------ Build started: Project: STM32F4_libOpenCM3, Configuration: Debug VisualGDB ------ 1>C:\Program Files (x86)\Sysprogs\VisualGDB\MSBuild\Targets\link.targets(40,2): warning : Multiple linker script files included in the project. None of them will be used in linking. Please exclude mark the unnecessary ones as 'Excluded from build' 1> Linking VisualGDB/Debug/STM32F4_libOpenCM3... 1> c:/program files (x86)/gnu tools arm embedded/5.4 2016q3/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe:libopencm3_stm32f4.ld:43: warning: memory region `rom' not declared 1> c:/program files (x86)/gnu tools arm embedded/5.4 2016q3/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe:libopencm3_stm32f4.ld:86: warning: memory region `ram' not declared 1> ------------------- Memory utilization report ------------------- 1> Used FLASH: 0 bytes out of 512KB (0%) [-660] 1> Used RAM: 0 bytes out of 128KB (0%) ========== Build: 1 succeeded, 0 failed, 0 up-to-date, 0 skipped ==========
This reply was modified 8 years, 10 months ago by
support. Reason: formatting
November 21, 2017 at 21:36 #13031support
The warning message is actually legitimate: you have included multiple .ld files in your project, but didn’t specify via VisualGDB Project Properties which one is the main one. VisualGDB arbitrarily guesses the first one (and guesses it wrong).
Please specify the linker script explicitly via VisualGDB Project Properties or change the file type of the unused linker script to “Does not participate in build”:
You must be logged in to view attached files.November 22, 2017 at 00:51 #13033sidprice
ParticipantThank you, this solved the build issue with the reference project and I was able to create a project using the generated template.
Please ignore the attached file, it was uploaded in error.
Sid
sidprice.
sidprice.
You must be logged in to view attached files.November 22, 2017 at 17:39 #13043sidprice
ParticipantOne small issue that could be improved upon.
Note in my last post I uploaded a screen shot. I did this because when I tried to make a project using my template I was told to select a tool chain, even though the wizard had selected the right one. The screen shot shows that.
I found that if I selected another toolchain then went back to the correct one the error went away, I did not realize this was the case so I changed my post to say it was working.
This morning I tried the wizard again and got the same effect, it was resolved using the procedure I just described.
Not a huge problem but one that may confuse others.
Sid
November 27, 2017 at 06:26 #13077support
Sorry for the delayed reply. We have tried reproducing this with different toolchains and device settings, but could not get any similar behavior. Please ensure that you are using the latest VisualGDB 5.3R6. Please also feel free to share your template file with us. As it looks like a VisualGDB bug, we will be happy to fix it if we can reproduce the problem on our side.
December 3, 2017 at 02:13 #13138sidprice
ParticipantMy turn to be slow responding. Attached is the custom template for your testing.
Sid
December 3, 2017 at 02:15 #13139sidprice
ParticipantOnce again your server rejected my file …
You must be logged in to view attached files.December 3, 2017 at 06:10 #13141support
Thanks, we have tried reproducing this with your template file, but unfortunately could not get anything similar. Most likely the problem is caused by some combination of installed/referenced toolchain versions. If this is too annoying, we can add extra diagnostic logging to the logic responsible for the toolchain selection, so it will explain what is causing this with your setup. Let us know if you would like to try it out.
December 8, 2017 at 17:29 #13201sidprice
ParticipantThanks, it is annoying but not a show stopper. I would be happy to work with you to trace the issue if you would like,
Sid
December 13, 2017 at 02:06 #13261support
No problem, please try this build: http://sysprogs.com/files/tmp/VisualGDB-5.3.17.1957.msi
It will show detailed information on toolchain selection logic via View->Other Windows->VisualGDB Diagnostics Console. Please share the output from that window and we should be able to fix this.
