Custom pre-synchronization action?
Sysprogs forums Forums VisualGDB Custom pre-synchronization action?
  • #9396
    immcintosh
    Is there currently a way to specify actions to be executed before the file synchronization stage of a Linux project?  I’d like to run a script whenever a build is run to generate some versioning information that would itself be deployed as part of the deployment stage.  I’m using the “Copy source files to remote machine method,” and unfortunately all the custom build steps seem to be run after the copy.
    #9398
    The easiest way to achieve that would be to disable the normal source uploading and then do it via a custom pre-build action after running your script. If this does not work, please let us know.
    #9410
    immcintosh
    Thanks, that would work, although it sacrifices a lot of the convenience.  Can I register a feature request of adding an “Actions before synchronization” item to the custom build steps?
    #9413
    Sure, we will add this to the next maintenance release of VisualGDB 5.2.
    #9457
    OK, we have added it to this build: http://sysprogs.com/files/tmp/VisualGDB-5.2.13.1294.msi
    #9501
    immcintosh
    Great support, thanks, does just what I needed.
