Create embedded static library
Sysprogs forums › Forums › VisualGDB › Create embedded static library
  • #9693
    sidprice
    I tried to create a static library project using VisualGDB and it created a normal execution skeleton based upon a LED blonk example. Is there a tutorial for creating an embedded static library?
    Sid
    #9695
    VisualGDB indeed does not have a dedicated template for static Embedded libraries and will generate the usual LEDBlink code.
    It will still be a library project, so if you simple replace the generated code with your library functions and reference the library from your main project, it should work.
    #9699
    sidprice
    Thanks for the help,
    Sid
