When I run the following command within Powershell, the DLL seems to have failures.
<div>
<div>$AssemblyPath = "C:\Program Files (x86)\Sysprogs\VisualGDB\VisualGDBCore.dll"</div>
<div>
<div>
<div>$byteValues = [System.IO.File]::ReadAllBytes($AssemblyPath)</div>
<div>[System.Reflection.Assembly]::Load($byteValues)</div>
</div>
</div>
<div>
<div>
<div>$custObj = New-Object VisualGDB.Backend.LinuxProfiler.CoverageReportReader($inputFile, $null)</div>
</div>
</div>
</div>
Could not load file or assembly ‘SysprogsVSPluginInterfaces, Version=5.5.105.1, Culture=neutral, PublicKeyToken=8f764369eb712693’. The system cannot find the file specified.
However, this works on a different machine with the same VisualGDB 5.5r5. We did verify the DLL is within the directory above.
Could you please help?
Thank you,
Chris
