Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › Compile Errors
- This topic has 1 reply, 2 voices, and was last updated 15 years, 3 months ago by
jlam9012.
July 5, 2011 at 15:13 #324
ParticipantHey. I’m getting these errors when compiling a simple project with VC++ 2010 and VisualDDK.
1>
Build started: Project: TestDriver, Configuration: Release Win32
1>Build started 05/07/2011 16:03:56.
1>Build:
1> OACR monitor running already
1> path contains nonexistant c:program files (x86)microsoft visual studio 10.0common7toolsbin, removing
1> BUILD: Compile and Link for x86
1>
1> BUILD: Loading c:winddk7600.16385.1build.dat…
1>
1> BUILD: Computing Include file dependencies:
1>
1> BUILD: Start time: Tue Jul 05 16:03:56 2011
1> BUILD: Examining c:usersadmindocumentsvisual studio 2010projectstestdrivertestdriver directory for files to compile.
1>
1> c:usersadmindocumentsvisual studio 2010projectstestdrivertestdriver
1>
1> BUILD: Saving c:winddk7600.16385.1build.dat…
1>
1> BUILD: Compiling and Linking c:usersadmindocumentsvisual studio 2010projectstestdrivertestdriver directory
1>
1> Configuring OACR for ‘root:x86fre’ –
1> _NT_TARGET_VERSION SET TO WINXP
1> 1>errors in directory c:usersadmindocumentsvisual studio 2010projectstestdrivertestdriver
1>c:winddk7600.16385.1binmakefile.new(7117): error U1087: cannot have : and :: dependents for same target
1> 1>nmake.exe /nologo BUILDMSG=Stop. -i /nologo /f c:winddk7600.16385.1binmakefile.def BUILD_PASS=PASS2 LINKONLY=1 NOPASS0=1 MAKEDIR_RELATIVE_TO_BASEDIR= failed – rc = 2
1>
1> BUILD: Finish time: Tue Jul 05 16:03:57 2011
1> BUILD: Done
1>
1>
1>
1> 0 files compiled – 1 Warning – 2 Errors
1>
1>C:Program Files (x86)MSBuildMicrosoft.Cppv4.0Microsoft.MakeFile.Targets(38,5): error MSB3073: The command “call C:WINDDK7600.16385.1binsetenv.bat C:WINDDK7600.16385.1 fre wxp
1>C:Program Files (x86)MSBuildMicrosoft.Cppv4.0Microsoft.MakeFile.Targets(38,5): error MSB3073: cd /d c:Usersadmindocumentsvisual studio 2010ProjectsTestDriverTestDriver
1>C:Program Files (x86)MSBuildMicrosoft.Cppv4.0Microsoft.MakeFile.Targets(38,5): error MSB3073: build” exited with code 1.
1>
1>Build FAILED.
1>
1>Time Elapsed 00:00:01.02
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========#include
PDEVICE_OBJECT DeviceObject = NULL;
void DriverUnload(PDRIVER_OBJECT pDriverObject)
IoDeleteDevice(DeviceObject);
DbgPrint("Driver unloadedn");
NTSTATUS DriverEntry(PDRIVER_OBJECT DriverObject, PUNICODE_STRING RegistryPath)
UNICODE_STRING DeviceName;
NTSTATUS Status;
PCWSTR szDeviceName = L"\Device\DeviceDriver";
DbgPrint("Driver loadedn");
RtlInitUnicodeString(&DeviceName, szDeviceName);
Status = IoCreateDevice(DriverObject, 0, &DeviceName, FILE_DEVICE_NULL, 0, FALSE, &DeviceObject);
if (Status == STATUS_SUCCESS)
DbgPrint("Device createdn");
else
DbgPrint("IoCreateDevice failed: %xn", Status);
DriverObject->DriverUnload = DriverUnload;
return STATUS_SUCCESS;
}The same code compiles fine in the x86 Checked Build Environment.
July 7, 2011 at 16:25 #1888jlam9012
Participant>c:winddk7600.16385.1binmakefile.new(7117): error U1087: cannot have : and :: dependents for same target
I was getting something like this too and it means that you can’t have spaces in your build directory.
The spacing with “visual studio 2010” might be giving you the error. Put your project in C: or someplace else without any spaces.
