Sysprogs forums › Forums › VisualGDB › Compilation errors importing Keil project
- This topic has 3 replies, 3 voices, and was last updated 6 years, 12 months ago by
MystikReasons.
March 21, 2019 at 23:22 #24410
danielone
ParticipantHello there,
I was able to import a Keil project, but, compiling with Keil ARMCC I get compilation errors in several functions defined in cmsis_armcc.h
In new project settings I chose “Automatically import a project in different format” –> Import an existing Keil Project selecting Keil ARM Compiler.
Sometimes I also get a: error : Designtime build failed for project ‘C:\Users\xxxxxx\source\repos\EmbeddedProject1\EmbeddedProject1\EmbeddedProject1.vcxproj’ configuration ‘Debug|VisualGDB’. IntelliSense might be unavailable.
Set environment variable TRACEDESIGNTIME = true and restart Visual Studio to investigate.
BTW The compiler output is not the same I get with ARMCC Compiler… it looks like the code is not compiled with ARMCC toolchain despite it is selected in project options.
MCU is STM32F030R8, CubeMX package for STM32F0 installed, last version, the same for the Keil uVision package.
How to solve?
You must be logged in to view attached files.March 22, 2019 at 02:57 #24412support
Most likely, the original project contains some special settings that were not automatically imported.
The easiest way is to narrow this down to a specific source file and then compare the build command lines used by the Keil IDE and by VisualGDB. You can find the VisualGDB’s command lines in the .rsp files inside <project directory>\VisualGDB\Debug. The command lines from the Keil IDE can be found by enabling the .bat file generation and looking through the generated file (it will use the –Via <filename> syntax where <filename> will correspond to the response files generated by Keil).
Once you find out a specific command-line argument, we can help you locate the corresponding VisualGDB setting.
March 22, 2019 at 11:07 #24423MystikReasons
Participant@danielone I have the same problem: https://sysprogs.com/w/forums/topic/keil-armcc-features-error/
It seems that the Keil compiler in VC doesn’t support the ASM keyword (assembly inline)
This is the description of the error from keil http://www.keil.com/support/man/docs/ARMERR/armerr_dom1365070466238.htm:
1114: this feature not supported on target architecture/processor
Example when compiled with armcc –cpu 4T:
int main(void) {
int a,b,c;
__asm {
QADD a,b,c
return(a);
}results in an error message because the saturated add instruction is only supported in ARMv5TE and later.”
But I don’t know why its not supported because I use the default compiler version 5 in Keil and in Visual Studio too.
This reply was modified 6 years, 12 months ago by
MystikReasons.
MystikReasons.
March 22, 2019 at 11:20 #24426MystikReasons
ParticipantI found that the inline assembler for v5 is mostly supported: http://www.keil.com/support/man/docs/armcc/armcc_chr1359124246466.htm
The not supported commands can be found here: http://www.keil.com/support/man/docs/armcc/armcc_chr1359124246684.htm
But my errors have other commands so it should support them.
