CMake Warning
Sysprogs forums Forums VisualGDB CMake Warning
  • #36208
    intector
    I always get the message:
    CMake Warning:
      Manually-specified variables were not used by the project:
          LOCALAPPDATA
    Everything works fine, it’s just so annoying. Is there any way to get rid of that message?
    #36210
    bflannery
    You can suppress the warning by using the variable.
    Add this to your CMakeLists.txt
    Here we set ignoreMe to the variable thereby using it.
    • This reply was modified 1 year, 3 months ago by bflannery.
    #36213
    Thanks for sharing this. This is a leftover from the BSP system layout that used the path explicitly (it can still use it now in some cases like manually overridden per-file settings) and this workaround should indeed work just fine.
    If anyone else finds the message too annoying, feel free to post here. If it bothers enough users, we can add a better workaround on our side.
    #36239
    intector
    Hey Guys,
    That works just fine, thanks.
