I’m having issue with the intellisense. It’s showing underlines on bool/true/false, saying “Use of undeclared identifier bool”. But the file can actually compile.
I think the problem may be some version discrepancy. In stdbool.h, it’s not declaring the type because it thinks it should be keywords, while clang doesn’t think so:
#if defined __STDC_VERSION__ && __STDC_VERSION__ > 201710L
/* bool, true and false are keywords. */
#else
#define bool _Bool
#define true 1
#define false 0
#endif
Example code to reproduce: Note the extension of the file is .c, not cpp.
The GCC tool chain version is 15.2.1/15.2/r1
#include
int main(void)
bool aaa = false;
return 0;
cmake_minimum_required(VERSION 3.15)
project(EmbeddedProject1_bool LANGUAGES C CXX ASM)
find_bsp(
ID com.sysprogs.arm.stm32f4
VERSION 1.28.0
MCU STM32F407VE
FRAMEWORKS com.sysprogs.arm.stm32.hal com.sysprogs.arm.stm32.ll
HWREGISTER_LIST_FILE STM32F4xxxx/DeviceDefinitions/stm32f407xx.xml
DISABLE_GNU_EXTENSIONS)
add_bsp_based_executable(
NAME EmbeddedProject1_bool
SOURCES EmbeddedProject1_bool.c system_stm32f4xx.c stm32f4xx_hal_conf.h
GENERATE_BIN
GENERATE_MAP
OUTPUT_RELOCATION_RECORDS)
Is there any way to fix that?
Regards,
Tianyi
This topic was modified 1 month ago by
wtywtykk.
