Clang Find Results highlight color
Sysprogs forums › Forums › VisualGDB › Clang Find Results highlight color
  • #8948
    sidprice
    I am using the “Dark” theme with VS 2015 and I cannot find a way of changing the highlight colors in the Find Results [clang] window. It has a bright yellow background and white text which is pretty much impossible to read. Where can this be changed please? I have looked through the Tools/Options/Fonts and Colors settings and this window is not mentioned there and I don’t see it under the VisualGDB settings either.
    Many thanks,
    Sid
    #8953
    If  you are using VisualGDB 5.2 Preview 2 or later, you can change those colors via Tools->Options->Environment->Fonts and colors->Text Editor->Code reference, Code reference (C/C++ macro) and Code reference (write).
