Sysprogs forums › Forums › VisualGDB › CC3200 Launchpad SWD
- This topic has 4 replies, 2 voices, and was last updated 9 years, 5 months ago by
ciaranmaca.
September 6, 2016 at 11:52 #8985
ciaranmaca
I have JTAG connectivity working well with my CC3200 Launchpad (FTDI 2232 based debug connectivity). I want to switch to SWD to save pins. How can I do this?
I tried adding ‘transport select swd’ to one of my scripts but it also needed me to switch the jtag tap commands to ‘swd’ (and of course set the SOP settings right on my board). But I get errors in openocd. “ession transport is “swd” but your config requires JTAG” etc.
Any one done this?
Ciarán
September 7, 2016 at 04:10 #8993support
Have you tried explicitly selecting the SWD transport in the VisualGDB Project Properties window?
September 7, 2016 at 09:58 #9003ciaranmaca
No, that didn’t work either. I get the following error:
Ciarán
^error,msg=”-var-assign: Could not assign expression to variable object”
-exec-continue
^error,msg=”Warning:\nCannot insert breakpoint 1.\nCannot access memory at address 0x20004ac8\n”— GDBServer output —
Open On-Chip Debugger 0.9.0 (2016-09-01) [https://github.com/sysprogs/openocd]Licensed under GNU GPL v2
For bug reports, read
adapter speed: 1000 kHz
jtag
adapter_nsrst_delay: 100
jtag_ntrst_delay: 100
cortex_m reset_config sysresetreq
VisualGDB_OpenOCD_Ready
Info : clock speed 1000 kHz
Error: JTAG scan chain interrogation failed: all zeroes
Error: Trying to use configured scan chain anyway…
Error: cc3200.jrc: IR capture error; saw 0x00 not 0x01
Info : accepting ‘gdb’ connection on tcp/63987
undefined debug reason 7 – target needs reset
Error: Target not examined yet
September 11, 2016 at 18:54 #9036support
We have rechecked the OpenOCD support for FTDI and CC3200 and it looks like the current FTDI configuration files do not support the SWD signals yet.
There are third-party articles describing how to define them, but we have not retested those instructions. We would expect the OpenOCD maintainers to update the configuration files in the next few releases.
Also if you encounter errors like “The current target requires JTAG”, please try switching OpenOCD to manual configuration mode and replacing the cc3200.cfg script with the cc32xx.cfg.
If this does not help, please let us know.
September 12, 2016 at 13:08 #9038ciaranmaca
Thanks for the reply. Yes, I set the target to cc32xx.cfg and that got me partly there. I still hard an error about signal definitions. But taking inspiration from the gcc scripts in the tools folder of the TI SDK for CC3200 I added these two lines to the interface/ftdi/cc3200lp.cfg script:
# Add for SWD
ftdi_layout_signal SWD_EN -ndata 0x0080
ftdi_layout_signal SWDIO_OE -data 0x0008And hurray, it works.
Thanks for your help. I consider the issue resolved.
Ciarán
