Sysprogs forums › Forums › VisualGDB › cc: error: ProvideDirectories: No such file or directory
- This topic has 7 replies, 2 voices, and was last updated 9 years, 11 months ago by
slavav.
October 10, 2016 at 16:57 #9255
slavav
source: VS2015; target: Ubuntu, virtual, hyper-V
simple static lib – 1-2 files – not problem – compiled fantastic.
after adding several files into project (using d-n-d from explorer) – this error:
1>—— Rebuild All started: Project: sqlite, Configuration: Debug VisualGDB ——
1> VisualGDB: Run “rm -rf “/tmp/VisualGDB/c/Git/Archive-Dashboard-WxWin/vpacs/linux/sqlite/VisualGDB/Debug”” in directory “” on slava@192.168.0.100 (SSH)
1> VisualGDB: Sending 56 updated source files to build machine…
1> VisualGDB: Run “make -f “VisualGDB/Debug/sqlite.msbuild-mak”” in directory “/tmp/VisualGDB/c/Git/Archive-Dashboard-WxWin/vpacs/linux/sqlite” on slava@192.168.0.100 (SSH)
1> os.c
1> sqlite.cpp
1> cc build.c ProvideDirectories UpdateRSP/VisualGDB/Debug/os.o UpdateRSP/VisualGDB/Debug/sqlite.o UpdateRSP/../VisualGDB/Debug/sqlite.ar.rsp ../VisualGDB/Debug/sqlite.a -o build
1> cc: error: ProvideDirectories: No such file or directory
1> cc: error: UpdateRSP/VisualGDB/Debug/os.o: No such file or directory
1> cc: error: UpdateRSP/VisualGDB/Debug/sqlite.o: No such file or directory
1> cc: error: UpdateRSP/../VisualGDB/Debug/sqlite.ar.rsp: No such file or directory
1> <builtin>: recipe for target ‘build’ failed
1> make: *** [build] Error 1
1> ————————————————————-
1> Command exited with code 2
1> Executable: make
1> Arguments: -f “VisualGDB/Debug/sqlite.msbuild-mak”
1> Directory: /tmp/VisualGDB/c/Git/Archive-Dashboard-WxWin/vpacs/linux/sqlite
1> VisualGDB: Error: Command-line action failed
1> error: Build has failed. See the Output window for more details.
1>C:\Program Files (x86)\Sysprogs\VisualGDB\MSBuild\Targets\remote.targets(15,2): error : Build failed. Please examine the build output (View->Output) for details.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
Thanks.
Is maybe some option exists to use absolute path and not relative via RSP?
Due to files exists on target system
October 10, 2016 at 22:23 #9258support
This looks like the Makefile got corrupt somehow. Could you please attach it so that we could quicky check for common problems?
October 11, 2016 at 07:56 #9261slavav
ParticipantI couldn’t understand how to insert sqlite.msbuild-mak file. Thus content:
#This file is generated by VisualGDB from your MSBuild project.
#Do not edit it manually as it will be regenerated on each build.
#You can build this project manually by running the following command line:
# make -f <path to this file>
#The ‘prepare’ target needs to be built before the ‘build’ target to ensure all
#response files are up-to-date
ifneq ($(VERBOSE),1)
_V := @
endif
build:
ProvideDirectories:
@mkdir -p VisualGDB/Debug/
PREPARE_TARGETS := ProvideDirectories
#ClCompile – 2 files
$(_V)echo “-ggdb -O0 -DDEBUG=1 -ffunction-sections -fdata-sections” > VisualGDB/Debug/os.gcc.rsp-new
$(_V)cmp –silent VisualGDB/Debug/os.gcc.rsp-new VisualGDB/Debug/os.gcc.rsp || cp VisualGDB/Debug/os.gcc.rsp-new VisualGDB/Debug/os.gcc.rsp
$(_V)echo “-ggdb -O0 -DDEBUG=1 -ffunction-sections -fdata-sections” > VisualGDB/Debug/sqlite.gcc.rsp-new
$(_V)cmp –silent VisualGDB/Debug/sqlite.gcc.rsp-new VisualGDB/Debug/sqlite.gcc.rsp || cp VisualGDB/Debug/sqlite.gcc.rsp-new VisualGDB/Debug/sqlite.gcc.rsp
-include VisualGDB/Debug/os.dep
VisualGDB/Debug/os.o: os.c VisualGDB/Debug/os.gcc.rsp
@echo os.c
$(_V)gcc @VisualGDB/Debug/os.gcc.rsp -c “os.c” -o “VisualGDB/Debug/os.o” -MD -MP -MF “VisualGDB/Debug/os.dep”
-include VisualGDB/Debug/sqlite.dep
VisualGDB/Debug/sqlite.o: sqlite.cpp VisualGDB/Debug/sqlite.gcc.rsp
@echo sqlite.cpp
$(_V)g++ @VisualGDB/Debug/sqlite.gcc.rsp -c “sqlite.cpp” -o “VisualGDB/Debug/sqlite.o” -MD -MP -MF “VisualGDB/Debug/sqlite.dep”
PREPARE_TARGETS += UpdateRSP/VisualGDB/Debug/os.o UpdateRSP/VisualGDB/Debug/sqlite.o
CLCOMPILE_TARGETS += VisualGDB/Debug/os.o VisualGDB/Debug/sqlite.o
$(_V)mkdir -p “../VisualGDB/Debug”
$(_V)echo “-r ../VisualGDB/Debug/sqlite.a VisualGDB/Debug/os.o VisualGDB/Debug/sqlite.o” > ../VisualGDB/Debug/sqlite.ar.rsp-new
$(_V)cmp –silent ../VisualGDB/Debug/sqlite.ar.rsp-new ../VisualGDB/Debug/sqlite.ar.rsp || cp ../VisualGDB/Debug/sqlite.ar.rsp-new ../VisualGDB/Debug/sqlite.ar.rsp
../VisualGDB/Debug/sqlite.a: ../VisualGDB/Debug/sqlite.ar.rsp VisualGDB/Debug/os.o VisualGDB/Debug/sqlite.o
$(_V)ar @../VisualGDB/Debug/sqlite.ar.rsp
PREPARE_TARGETS += UpdateRSP/../VisualGDB/Debug/sqlite.ar.rsp
FINAL_TARGETS += ../VisualGDB/Debug/sqlite.a
.PHONY: $(PREPARE_TARGETS)
build: $(PREPARE_TARGETS) $(FINAL_TARGETS)
This reply was modified 9 years, 11 months ago by
slavav.
October 12, 2016 at 15:37 #9267slavav
ParticipantI use trial. Is there trial limitation for… number of files? project dependancies?
due to very strange error.
I create new static lib project – build OK
add 2-3 files – build OK
I create another static lib project – Build OK
I add reference from one project to another – build error.
remove reference – doesn’t help.
Another situation:
new project – buld OK
add 1-2 new files – build OK
add 3-rd file – build fail. Why????
I remove this 3-rd file – build failed at any rate. That’s all. Visually make file looks good for me
October 13, 2016 at 05:05 #9275support
There are no functional limitations in the trial version. The VisualGDB MSBuild backend is relatively new, so this actually looks like a bug triggered by “..” in some of the paths.
Could you please send your .vcxproj, .filters, .vgdbsettings and .sln files to support@sysprogs.com? This should help us reproduce and fix this.
October 25, 2016 at 08:17 #9350slavav
ParticipantSent. Thanks!!! I sit crossing fingers )))
ps: I forget to send sln, but nothing special in it:
Microsoft Visual Studio Solution File, Format Version 12.00
# Visual Studio 14
VisualStudioVersion = 14.0.25123.0
MinimumVisualStudioVersion = 10.0.40219.1
Project(“{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}”) = “tesst”, “tesst\tesst.vcxproj”, “{46E4911E-1E99-4B9F-9D81-C8C2037EC2F3}”
EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Debug|VisualGDB = Debug|VisualGDB
Debug|x64 = Debug|x64
Debug|x86 = Debug|x86
Release|VisualGDB = Release|VisualGDB
Release|x64 = Release|x64
Release|x86 = Release|x86
EndGlobalSection
GlobalSection(ProjectConfigurationPlatforms) = postSolution
{46E4911E-1E99-4B9F-9D81-C8C2037EC2F3}.Debug|VisualGDB.ActiveCfg = Debug|VisualGDB
{46E4911E-1E99-4B9F-9D81-C8C2037EC2F3}.Debug|VisualGDB.Build.0 = Debug|VisualGDB
{46E4911E-1E99-4B9F-9D81-C8C2037EC2F3}.Debug|x64.ActiveCfg = Debug|VisualGDB
{46E4911E-1E99-4B9F-9D81-C8C2037EC2F3}.Debug|x86.ActiveCfg = Debug|VisualGDB
{46E4911E-1E99-4B9F-9D81-C8C2037EC2F3}.Release|VisualGDB.ActiveCfg = Release|VisualGDB
{46E4911E-1E99-4B9F-9D81-C8C2037EC2F3}.Release|VisualGDB.Build.0 = Release|VisualGDB
{46E4911E-1E99-4B9F-9D81-C8C2037EC2F3}.Release|x64.ActiveCfg = Release|VisualGDB
{46E4911E-1E99-4B9F-9D81-C8C2037EC2F3}.Release|x86.ActiveCfg = Release|VisualGDB
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
EndGlobalSection
EndGlobal
slavav.
October 26, 2016 at 21:56 #9368support
Thanks, we have located and fixed the problem. It was caused by a conflict between an internal target called ‘build’ and build.c in your project. Please try this build: VisualGDB-5.2.12.1269.msi
October 28, 2016 at 14:16 #9382slavav
ParticipantYessss!! Thanks, I can build now. Continue checking further. Thanks!
