Can't use any c++ code in android projects only c code is usable
Sysprogs forums Forums VisualGDB Can't use any c++ code in android projects only c code is usable
  • #21744
    user612
    I came to a very strange problem
    I created the simple native activity for android and used ndk r17 and I have android sdks up to android 7
    I compiled the project as it is successfully
    later I added a cpp file and hpp file and wrote a very simple class that does no thing :
    class test {
    test() {}
    ~test() {}
    and set thee STL to c++_shared and ABI to armeabi-v7a and using exceptions rtti as c++ features
    but once I hit the build button I got several errors like these :
    • identifier “class” is undefined
    • cannot open source file “asm/posix_types.h”
    •  identifier “__u16” is undefined
    • unknown type name ‘class’; did you mean ‘jclass’?
    and very much errors
    what is the problem here ???
    #21758
    Please double-check that your source files have the .cpp, not .c extension. Even if one .c file included a header file with C++ constructs, it would result in a build error.
