Can't open Arduino project after manually editing boards.txt
Sysprogs forums Forums VisualGDB Can't open Arduino project after manually editing boards.txt
Viewing 13 posts - 1 through 13 (of 13 total)
  • #26602
    MystikReasons
    After manually editing the clock frequency of the Arduino UNO from 8MHz to 16MHz I got projects errors while reloading the project. So I closed Visual Studio and reopened it again and now its stuck loading the solution project.
    I changed it back to the previous clock frequency but it’s still stuck.
    How can I revert this?
    I’m using VisualGDB v. 5.5 build 3402.
    • This topic was modified 6 years, 7 months ago by MystikReasons.
    #26604
    MystikReasons
    Update: Every Arduino project is now having errors and won’t build because it has build errors. (see screenshot)
    Reloading the project doesn’t solve the issue.
    Loading cached code model from C:\Users\gwerderj\source\repos\Arduino_MIOTY_Dragino_sendString1\VisualGDBCache\Arduino_MIOTY_Dragino_sendString1-Debug-Arduino_Genuino_Uno\BuildCommandLines.txt…
    Failed to parse code model from C:\Users\gwerderj\source\repos\Arduino_MIOTY_Dragino_sendString1\VisualGDBCache\Arduino_MIOTY_Dragino_sendString1-Debug-Arduino_Genuino_Uno\CodeModel.json:System.Exception: Arduino code model did not report any sketch sources
    at bq2.j1.j_2(IEnumerable`1 a)
    Compiler output:
    Checking if any source files need uploading…
    Checking for file modifications…
    Found changed files since last query (see C:\Users\gwerderj\source\repos\Arduino_MIOTY_Dragino_sendString1\VisualGDBCache\Arduino_MIOTY_Dragino_sendString1-Debug-Arduino_Genuino_Uno\BuildFileStats.txt.old vs C:\Users\gwerderj\source\repos\Arduino_MIOTY_Dragino_sendString1\VisualGDBCache\Arduino_MIOTY_Dragino_sendString1-Debug-Arduino_Genuino_Uno\BuildFileStats.txt.new). Rerunning code model query..
    Saved the code model to C:\Users\gwerderj\source\repos\Arduino_MIOTY_Dragino_sendString1\VisualGDBCache\Arduino_MIOTY_Dragino_sendString1-Debug-Arduino_Genuino_Uno\BuildCommandLines.txt
    Compiler output:
    ========== Project Configuration Summary ==========
    Arduino_MIOTY_Dragino_sendString1 configured in 00:00
    ========== Configuration: 1 Succeeded, 0 Failed ==========
    • This reply was modified 6 years, 7 months ago by MystikReasons.
    #26607
    MystikReasons
    Launching Arduino builder…
    C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino\arduino-builder.exe -compile -logger=machine -fqbn=arduino:avr:uno -build-path C:\Users\gwerderj\source\repos\Arduino_MIOTY_Dragino_sendString1\Output\Arduino_Genuino_Uno\Debug -unoptimize=sketch -hardware “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/hardware” -hardware C:\Users\gwerderj\Documents/ArduinoData/packages -hardware C:\Users\gwerderj\AppData\Local/Arduino15/packages -tools “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/tools-builder” -tools C:\Users\gwerderj\Documents/ArduinoData/packages -tools C:\Users\gwerderj\AppData\Local/Arduino15/packages -libraries C:\Users\gwerderj\Documents/Arduino/Libraries -prefs=runtime.tools.avr-gcc.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 sketches/Arduino_MIOTY_Dragino_sendString1.ino
    Error reading file (C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\hardware\avr\1.8.1\boards.txt:0): Invalid line format, should be ‘key=value’
    Command exited with code 1
    Executable: C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino\arduino-builder.exe
    Arguments: -compile -logger=machine -fqbn=arduino:avr:uno -build-path C:\Users\gwerderj\source\repos\Arduino_MIOTY_Dragino_sendString1\Output\Arduino_Genuino_Uno\Debug -unoptimize=sketch -hardware “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/hardware” -hardware C:\Users\gwerderj\Documents/ArduinoData/packages -hardware C:\Users\gwerderj\AppData\Local/Arduino15/packages -tools “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/tools-builder” -tools C:\Users\gwerderj\Documents/ArduinoData/packages -tools C:\Users\gwerderj\AppData\Local/Arduino15/packages -libraries C:\Users\gwerderj\Documents/Arduino/Libraries -prefs=runtime.tools.avr-gcc.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 sketches/Arduino_MIOTY_Dragino_sendString1.ino
    Directory: C:\Users\gwerderj\source\repos\Arduino_MIOTY_Dragino_sendString1
    Command-line action failed
    ========== Project Build Summary ==========
    Arduino_MIOTY_Dragino_sendString1 built in 00:00
    ========== Build: 0 Succeeded, 1 Failed ==========
    Edit: I changed the clock frequency from 16 MHz to 8 MHz, not from 8 to 16 as stated above
    #26615
    It looks like you broke something in the platform files:
    The easiest way to fix it would be to just delete the arduino\hardware\avr folder, restart VS, and let VisualGDB download all the necessary packages from scratch.
    #26616
    MystikReasons
    I did as you said but it just complains about missing the ‘arduino:avr’. It doesn’t download any necessary packages.
    Reloading/building the project doesn’t help either.
    Loading cached code model from C:\Users\gwerderj\source\repos\Arduino_LORA\VisualGDBCache\Arduino_LORA-Debug-Arduino_Genuino_Uno\BuildCommandLines.txt…
    Failed to parse code model from C:\Users\gwerderj\source\repos\Arduino_LORA\VisualGDBCache\Arduino_LORA-Debug-Arduino_Genuino_Uno\CodeModel.json:System.Exception: Arduino code model did not report any sketch sources
    Compiler output:
    Found changed files since last query (see C:\Users\gwerderj\source\repos\Arduino_LORA\VisualGDBCache\Arduino_LORA-Debug-Arduino_Genuino_Uno\BuildFileStats.txt.old vs C:\Users\gwerderj\source\repos\Arduino_LORA\VisualGDBCache\Arduino_LORA-Debug-Arduino_Genuino_Uno\BuildFileStats.txt.new). Rerunning code model query..
    Failed to locate best tools for arduino:avr:uno: Platform ‘arduino:avr’ is not installed.
    Saved the code model to C:\Users\gwerderj\source\repos\Arduino_LORA\VisualGDBCache\Arduino_LORA-Debug-Arduino_Genuino_Uno\BuildCommandLines.txt
    Compiler output:
    Arduino_LORA configured in 00:00
    #26617
    Please try creating a new project from scratch. Please also update to VisualGDB-5.5.2.3403.msi. This version will download missing packages when you open the project, given that it was fully loaded before (won’t help for projects that were never loaded with the new build).
    #26618
    MystikReasons
    You forgot to mention that I have to install the Arduino AVR Boards package in the visualgdb package manager window, I thought it would do it himself.
    After reloading the project I’m still having build errors:
    Compiler output:
    Compiler output:
    Update to your last post: I will try build 3403
    #26620
    MystikReasons
    Okay so after creating a new project from scratch with the Uno it already has build errors (just created the project).
    I’m using your new build 3403.
    C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino\arduino-builder.exe -compile -logger=machine -fqbn=arduino:avr:uno -build-path C:\Users\gwerderj\source\repos\Arduino_MIOTY_LORA_LIKE_Dragino_BME280\Output\Arduino_Genuino_Uno\Debug -unoptimize=sketch -hardware “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/hardware” -hardware C:\Users\gwerderj\Documents/ArduinoData/packages -hardware C:\Users\gwerderj\AppData\Local/Arduino15/packages -tools “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/tools-builder” -tools C:\Users\gwerderj\Documents/ArduinoData/packages -tools C:\Users\gwerderj\AppData\Local/Arduino15/packages -libraries C:\Users\gwerderj\Documents/Arduino/Libraries -prefs=runtime.tools.avr-gcc.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 sketches/Arduino_MIOTY_LORA_LIKE_Dragino_BME280.ino
    Error reading file (C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\hardware\uni_erlangen\1.8.1\boards.txt:0): Invalid line format, should be ‘key=value’
    Arguments: -compile -logger=machine -fqbn=arduino:avr:uno -build-path C:\Users\gwerderj\source\repos\Arduino_MIOTY_LORA_LIKE_Dragino_BME280\Output\Arduino_Genuino_Uno\Debug -unoptimize=sketch -hardware “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/hardware” -hardware C:\Users\gwerderj\Documents/ArduinoData/packages -hardware C:\Users\gwerderj\AppData\Local/Arduino15/packages -tools “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/tools-builder” -tools C:\Users\gwerderj\Documents/ArduinoData/packages -tools C:\Users\gwerderj\AppData\Local/Arduino15/packages -libraries C:\Users\gwerderj\Documents/Arduino/Libraries -prefs=runtime.tools.avr-gcc.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\tools\arduinoOTA\1.3.0 sketches/Arduino_MIOTY_LORA_LIKE_Dragino_BME280.ino
    Directory: C:\Users\gwerderj\source\repos\Arduino_MIOTY_LORA_LIKE_Dragino_BME280
    Arduino_MIOTY_LORA_LIKE_Dragino_BME280 built in 00:00
    #26621
    MystikReasons
    The new build also doesn’t want to install the missing package (‘arduino:avr’)
    C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino\arduino-builder.exe -compile -logger=machine -fqbn=arduino:avr:uno -build-path C:\Users\gwerderj\source\repos\Arduino_MIOTY_LORA_LIKE_Dragino_BME280\Output\Arduino_Genuino_Uno\Debug -unoptimize=sketch -hardware “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/hardware” -hardware C:\Users\gwerderj\Documents/ArduinoData/packages -hardware C:\Users\gwerderj\AppData\Local/Arduino15/packages -tools “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/tools-builder” -tools C:\Users\gwerderj\Documents/ArduinoData/packages -tools C:\Users\gwerderj\AppData\Local/Arduino15/packages -libraries C:\Users\gwerderj\Documents/Arduino/Libraries sketches/Arduino_MIOTY_LORA_LIKE_Dragino_BME280.ino
    Arguments: -compile -logger=machine -fqbn=arduino:avr:uno -build-path C:\Users\gwerderj\source\repos\Arduino_MIOTY_LORA_LIKE_Dragino_BME280\Output\Arduino_Genuino_Uno\Debug -unoptimize=sketch -hardware “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/hardware” -hardware C:\Users\gwerderj\Documents/ArduinoData/packages -hardware C:\Users\gwerderj\AppData\Local/Arduino15/packages -tools “C:\Program Files (x86)\Sysprogs\VisualGDB\Arduino/tools-builder” -tools C:\Users\gwerderj\Documents/ArduinoData/packages -tools C:\Users\gwerderj\AppData\Local/Arduino15/packages -libraries C:\Users\gwerderj\Documents/Arduino/Libraries sketches/Arduino_MIOTY_LORA_LIKE_Dragino_BME280.ino
    #26623
    MystikReasons
    I also noticed that if you change the hardware directories under Arduino Settings and revert these changes it won’t take the new values.
    See my post above: Error reading file (C:\Users\gwerderj\Documents\ArduinoData\packages\arduino\hardware\uni_erlangen\1.8.1\boards.txt:0): Invalid line format, should be ‘key=value’
    You see the “uni_erlangen” keyword above but it’s not in the actual hardware directories paths anymore.
    #26640
    MystikReasons
    Okay so I figured out why it still used uni_erlangen as reference. I thought VisualGDB is using the following path for their packages: …\AppData\Local\Arduino15\packages\arduino\hardware but I found out its using the following path: …\Documents\ArduinoData\packages\arduino\hardware\avr.
    After clearing everything what was in it (the uni_erlangen and the avr folder) I restarted Visual Studio and the path was still selected as …\uni_erlangen\…   So this has to be a bug. It still didn’t download the missing package.
    So I created a new project and in the device selection it told me to download the avr boards package and this finally installed the package. In the newly created project the build errors disappeared.
    And also in every other project the build errors disappeared and the window for the missing packages finally appeared.
    Even the projects which wouldn’t open themself anymore are now loading properly.
    #26641
    MystikReasons
    Is the build 3403 missing package feature only for libraries or also for platforms?
    That would explain why it didn’t resolve the mssing “Arduino AVR Boards” package on his own.
    Would you be able to improve your missing package feature to also locate missing platforms?
    PS: The “Resolve Project Load Issues” window is only showing when you have installed the necessary platform files (in my example: the Arduino AVR Boards package).
    #26699
    The new build should report missing platforms as well, however only if they are known to VisualGDB (i.e. listed in one of the platform_index.json files configured via Tools->VisualGDB->Arduino->Package index URLs).
