Sysprogs forums › Forums › VisualGDB › Can't launch VisualGDB debugger
- This topic has 1 reply, 2 voices, and was last updated 3 years, 7 months ago by
August 19, 2022 at 07:43 #33061
mattia
ParticipantHello,
after I moved to 5.6R7 I am unable to debug an old project: I get this message in diagnostics:
ShouldRedirectToVisualGDBImpl(): C:\Work\Progetti\_SOURCE\15_Firmware\FW00018-FW_APP_REMSMPC_HMI4.3_V01\03_SourceApp\FW00018-FW_APP_REMSMPC_HMI4.3_V01\FW00018-FW_APP_REMSMPC_HMI4.3_V01-Debug.vgdbsettings vgdb://TargetPath=C:\Work\Progetti\_SOURCE\15_Firmware\FW00018-FW_APP_REMSMPC_HMI4.3_V01\03_SourceApp\FW00018-FW_APP_REMSMPC_HMI4.3_V01\VisualGDB\Debug\FW00018-FW_APP_REMSMPC_HMI4.3_V01 Found RTOS in C:\Work\Progetti\_SOURCE\15_Firmware\FW00018-FW_APP_REMSMPC_HMI4.3_V01\03_SourceApp\FW00018-FW_APP_REMSMPC_HMI4.3_V01\VisualGDB\Debug\FW00018-FW_APP_REMSMPC_HMI4.3_V01: FreeRTOS gdb session initialization failed at stage 7: ------------------ System.ArgumentNullException ------------------ System.ArgumentNullException: Il valore non può essere null. Nome parametro: source in System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source) in l53.i1() in l53..ctor(EmbeddedTimestampProvider a, Double c, Dispatcher b) in jt2..ctor(c4 a, EmbeddedDebugSubsystemSettings b, vs1 f, ge2 c, GDBSessionLaunchOptions d, ManagedToolchain e) in ge2.g_2(c4 b, GDBSessionLaunchOptions a) in c4..ctor(VisualGDBProjectSettings2 c, hp d, GDBSessionLaunchOptions a, zg3 b, Boolean e) in h82..ctor(GDBSessionLaunchOptions b, tc2 a) trace=[System.Linq.Enumerable.ToArray:3, l53.i1:0, l53..ctor:53, jt2..ctor:1275, ge2.g_2:76, c4..ctor:125, h82..ctor:332] Unexpected exception: ------------------ System.ArgumentNullException ------------------ System.ArgumentNullException: Il valore non può essere null. Nome parametro: source in System.Linq.Enumerable.ToArray[TSource](IEnumerable`1 source) in l53.i1() in l53..ctor(EmbeddedTimestampProvider a, Double c, Dispatcher b) in jt2..ctor(c4 a, EmbeddedDebugSubsystemSettings b, vs1 f, ge2 c, GDBSessionLaunchOptions d, ManagedToolchain e) in ge2.g_2(c4 b, GDBSessionLaunchOptions a) in c4..ctor(VisualGDBProjectSettings2 c, hp d, GDBSessionLaunchOptions a, zg3 b, Boolean e) in h82..ctor(GDBSessionLaunchOptions b, tc2 a) in tc2..ctor(GDBSessionLaunchOptions a) in yl3.b_2(xk1 a) in VisualGDB.GDBDebugEngine.Attach(IDebugProgram2[] e, IDebugProgramNode2[] a, UInt32 c, IDebugEventCallback2 d, enum_ATTACH_REASON b) trace=[System.Linq.Enumerable.ToArray:3, l53.i1:0, l53..ctor:53, jt2..ctor:1275, ge2.g_2:76, c4..ctor:125, h82..ctor:872, tc2..ctor:90, yl3.b_2:129, VisualGDB.GDBDebugEngine.Attach:32]
And I can’t debug it anymore. I tried a new project, and it works without any problems.
Is it related to the new version?
Thank you,
Mattia Berton
August 19, 2022 at 19:47 #33066support
KeymasterSorry about that, it’s indeed a bug introduced by another fix in v5.6R7. We have fixed it in the following build: VisualGDB-5.6.107.4696.msi
