can't import keil to visualgdb sucessfully
Sysprogs forums › Forums › VisualGDB › can't import keil to visualgdb sucessfully
  • #31978
    nimenhaoa
    though I can import keil project to visualgdb, I fail to build it, if I use gcc compiler
    #31979
    nimenhaoa
    this is the keil source project
    #31980
    nimenhaoa
    hh
    #31982
    This is to be expected. Porting a project to a different compiler will likely require adjusting it to account for differences between the compilers. As soon as you adjust the source code fixing the build errors, VisualGDB will let you build and debug the project as usual.
