Can't create .iso properly, all filenames stored as UpperCase!
Sysprogs forums › Forums › WinCDEmu › Can't create .iso properly, all filenames stored as UpperCase!
  • #9102
    saeedserpooshan
    When i create an .iso from a (office 2013 setup) folder, all files become in UPPER-CASE, and generated image does not run properly (gives a missing file error!)
    it could be related to different filename cases or other bugs in WinCDEmu …
    are there any setting to be set for proper filename…?
    #25052
    DnsFR
    Same issue as reported here:
    https://github.com/sysprogs/WinCDEmu/issues/19
    • This reply was modified 7 years, 3 months ago by DnsFR.
    #25056
    The Welder
    This is caused by you creating .iso files using the ISO-9660 standard.  If you do this, then all filenames will be converted to uppercase as this is what the standard defines and also, filenames will be 8 characters long with a 3 character extension.  Longer filenames will either be truncated, or end up with a tilde in them.  (DOS 8.3 format, I think)
    Anyway, if you want to create an .iso so that it contains filenames longer than 8 characters, then you need to create a Joliet CD.  Since I am new here, but know a great deal about CD formats, I know this is what is causing you problems.  What I do NOT know is whether WinCDEmu supports creating such CD’s.  It should though.  Also, you should specify what you want to use the ASCII character set too, as the ISO standard only supports uppercase characters.
    Personally, I probably wouldn’t use WinCDEmu to create .iso images and use something a bit more dedicated to the task.  Software such as Nero, UltraISO or PowerISO are the things you need for really creating compliant .iso images.
    #25057
    DnsFR
    OK, I’ve added a solution in GitHub Issue.
    I love OpenSource Software. 😉
