Can’t connect when use bootdebug option
Sysprogs forums › Forums › VisualDDK/VirtualKD discussion › Can’t connect when use bootdebug option
  • #347
    I’m using VMWare 7.1.4 + VirtualKD 2.5.4. Guest OS is Windows 7 Pro SP1
    I’m current work on a HBA driver, and I need debug from bootloader.
    So, I do such as thing:
    bcdedit /bootdebug {bootmgr} on
    The VirtualKD was work perfect, but after use bootdebug option, WinDBG can’t connect to guest OS.
    Then I try to use pipe com port, it’s connected!
    I guess that is bootloader try to access hardware directly, not via kdext module?
    Is there is any way to solve this problem? or I must debug via pipe com_1 ?
    #1958
    Not 100% sure, but I think I’ve stumbled upon some article from Microsoft explaining that the loader debugging is only possible using COM1. I would suggest googling around to see if anyone managed to set up other protocol for the bootloader (e.g. FireWire).
