Sysprogs forums › Forums › VisualGDB › Can't connect to yocto toolchain on WSL2_Win11
- This topic has 3 replies, 2 voices, and was last updated 4 years, 2 months ago by
December 15, 2021 at 07:59 #31889
drjonem
I’m trying to setup VisualGDB to build using a yocto toolchain stored on WSL2 running Ubuntu 20.04. The host system is Windows 11.
I have added the firewall rule as described in visualgdb/documentation/wsl2
I can select Windows 10 Linux Subsystem (Ubuntu 20.04) in project settings. However, when I go to CMake build settings and attempt to select the toolchain by selecting “Specify a yocto environment file”, VS hangs for two minutes before the following error is reported:
VisualGDB version: 5.6.102.4506
System.Exception: Bash process exited before connecting to output port.
See https://visualgdb.com/documentation/wsl2#launcher
Command line:
C:\WINDOWS\system32\wsl.exe –distribution Ubuntu-20.04 — /tmp/LinuxAppLauncher-v5 “/mnt/c/Users/jonma/AppData/Local/Temp/tmp4601.tmp” 60955 172.22.240.1
at g73.c.f1(CommandLineAction a, CommandFlags b, Boolean c)
at g73.c..ctor(k13 e, CommandLineAction d, CommandFlags c, jy a, Boolean b)
at g73.l_2(jy d, String b, String c, String e, ExpandedEnvironment a, CommandFlags f)
at ji1.n(String b, String c, ez2& a)
at ti2.c2(ni2 a)
at ti2.k(ni2 e, String d, String f, String b, l1 c, Boolean a)
at fj1.u(ni2 a, String d, String e, String c, l1 f, Boolean b)
at vw1.d(String a)
at vw1.Run()
at VisualGDB.Common_GUI.WPF.AdvancedToolchainSelectionControl.Controller.ImportToolchain(BasicToolchainProviderBase provider)
trace=[g73+c.f1:1205, g73+c..ctor:98, g73.l_2:36, ji1.n:0, ti2.c2:2, ti2.k:31, fj1.u:46, vw1.d:0, vw1.Run:0, VisualGDB.Common_GUI.WPF.AdvancedToolchainSelectionControl+Controller.ImportToolchain:0]I get the same result if I turn windows firewall off so it doesn’t seem to be firewall related.
LinuxAppLauncher-v5 is correctly created in the tmp folder on WSL2
If I try to run the command line shown above, then (after a couple of minutes) the system reports failed to connect to port 60955, error 110.
Any suggestions?
Jon
December 15, 2021 at 11:49 #31891support
No problem, please try checking the following:
- Does VisualGDB work with the same WSL distro using the default toolchain (not the Yocto one)?
- Does 172.22.240.1 correspond to the correct WSL network adapter? Is IPv4 enabled for it?
- Are you able to ping 172.22.240.1 (that should correspond to the Windows machine) from WSL and use it to telnet to TCP ports opened on the Windows machine?
December 16, 2021 at 07:01 #31898drjonem
I investigated Windows Firewall more closely – for some reason there were two rules for Visual Studio. I deleted one of them and now it is all working fine (and really well!).
The only odd thing is why turning Windows Firewall off didn’t help; maybe a Win 11 bug?
All I need to do now is create a separate platform for local (wsl) builds and remote builds and I will have a very flexible system.
Thanks for your help.
Jon.
December 16, 2021 at 10:17 #31901support
KeymasterThanks for letting us know and good to know it works. This makes sense, since VisualGDB relies on TCP/IP to communicate with WSL.
