Hi;
I installed Android Lollipop os, and I can’t connect to the device anymore. I get this error: error: only position independent executables (PIE) are supported.[/b
I don’t have problems with the 4.3 Android version, and I can attach to process and debug fine with it.
But with Android version 5, I have this issue.
I am using VisualGDB 4.3(Beta 2).
Any idea how to fix this?
Thank you.
GDB log:
-gdb-set solib-search-path C:/Users/ali/AppData/Local/VisualGDB/AndroidBinaryCache/073b16be;C:/Dev/D15/Build/DuelsAndroid/Duels/obj/local/armeabi-v7a
^done
Activating library load breakpoint bug workaround…
-break-insert -f *0xb6fd2b78
^done,bkpt={number=”1″,type=”breakpoint”,disp=”keep”,enabled=”y”,addr=”0xb6fd2b78″,at=””,times=”0″,original-location=”*0xb6fd2b78″}
-target-select remote :5039
^error,msg=”putpkt: write failed: No error.”
