Sysprogs forums › Forums › Other tools & products › Cannot start debugging
- This topic has 26 replies, 3 voices, and was last updated 14 years ago by
June 30, 2011 at 12:09 #318
ParticipantHi, have a problem.
I have installed VisualDDK on a Win7-64Bit Host machine.
I have Visual Studio 2008 and Visual Studio 2010 installed.
There were no problems during installation.On my guest PC (WinXP-32), i have started DDKLaunchMonitor.exe.
Firewalls are off. Host and guest are in same subnet.I set up a project from the WinDDKsrcgeneralpcidrvkdmf sample.
There were no build problems! pcidrv.sys builded succesfully.I go to Debug->Driver Launch Settings and set-up all the entries.
It doesn’t matter if i try COM connection, or Namedpipe:kd_VMXPPRO, when i press “Launch” i allways get:
VisualDDK Error
“VisualDDK:Cannot start debugging: Eine Bibliothekdatei, die zum Ausführen dieser Anwendung erfoderlich ist, wurde nicht
gefunden.”Means -> a DLL is missing!
Does anyone has any idea.
By the way..
* i started VS2010 as admin -> same error message!
* i started VS2008 as admin -> same error message!Seems that i need another dll.
My debuggerpath is:
%WinDDK%7600.16385.1DebuggersJune 30, 2011 at 12:14 #1850Anonymous
ParticipantI got the same error, when selecting
Debug-> Attach to process
Transport -> Kernel-mode connections
Qualifier: pipe://kd_VMXPPROERROR! unable to connect to ‘pipe://kd_VMXPPRO’
A dll is missing
June 30, 2011 at 12:45 #1851support
KeymasterHi, did you specify the path to a 32-bit version of Debugging tools?
June 30, 2011 at 13:13 #1852Anonymous
ParticipantYes i have downloaded the “Debbuging Tools for Windows” again, and installed it at this location:
C:Program Files (x86)Debugging Tools for Windows (x86)
But same problem…:
VisualDDK: Cannot start debugging. DLL missing.June 30, 2011 at 13:15 #1853support
KeymasterHave you specified the path to Debugging Tools in VisualDDK settings? (Tools->VisualDDK settings in VS).
June 30, 2011 at 13:24 #1854Anonymous
ParticipantYes i have.
And i have restarted VS2010, after changeing the path.
And i started VS2010 as admin… allways the same.Why cant he tell me wich DLL he is missing? I will try to figure it out with a dependenyie viewer.
June 30, 2011 at 13:26 #1855support
KeymasterThe DLL names are dbghelp.dll and dbgeng.dll both located in the debugging tools directory.
June 30, 2011 at 13:34 #1856Anonymous
ParticipantBoth dlls are present.
I think the problem are the plugin-dlls.
The DDKDebugLauncher.addin references “C:Program Files (x86)VisualDDKDDKDebugLauncher.dll”
When i have a look at DDKDebugLauncher.dll (with depends.exe) i see that
GPSVC.DLL
IESHIMS.DLLare missing.
June 30, 2011 at 13:45 #1857Anonymous
ParticipantI have only a 64 Version of gpsvc.dll installed on my system :(. I think that could be the problem
June 30, 2011 at 13:54 #1858support
KeymasterDDKDebugLauncher is a .Net module and should not be causing missing DLL problems. Could you download VisualDDK sources from SourceForge, compile DDKDebugLauncher (it will register itself automatically), set a breakpoint in BasicMSDbgSession::CreateClient() and step through to see what fails?
June 30, 2011 at 13:54 #1859Anonymous
Participant..and DDKDEBUGGGER.DLL needs MSVCR90.DLL, wich is also not present on my system
June 30, 2011 at 13:57 #1860Anonymous
I will try it tomorrow.
June 30, 2011 at 14:04 #1861Anonymous
ParticipantI copied MSVCR90.DLL + MSVCP90.DLL+MSVCM90.DLL into the VisualDKK folder, now its possible to connect over COM-Port, but when i select Named Pipe i still got the error 👿
I will download from SourgeForge tomorrow …
June 30, 2011 at 14:22 #1862Anonymous
ParticipantI have downladed and compiled the project with VS2008.
“DDKDebugLauncher.sln” contains has 3 projects..
DDKDebugLauncher
DDKDebugUI
DDKProjectHelpersI didnt find CreateClient -> i searched “Entire Solution” for “CreateClient”
I didnt find BasicMSDbgSession-> i searched “Entire Solution” for “BasicMSDbgSession”And how should i load the dll?
I tried: Debug-> Start External Program: “C:Program Files (x86)Microsoft Visual Studio 10.0Common7IDEdevenv.exe” (the VS2010 IDE) but that doesnt work!June 30, 2011 at 14:34 #1863support
KeymasterPlease use DDKDebugger.sln. DDKDebugLauncher is just a wrapper that starts driver projects.
