Cannot find Pkg-Config when compiling opencv
Sysprogs forums Forums VisualGDB Cannot find Pkg-Config when compiling opencv
  • #21966
    kennethone
    Hello, I am following the directions here:
    https://visualgdb.com/tutorials/raspberry/opencv/build/
    I copied pkg-config.exe to C:/SysGCC/Raspberry/bin
    I added cmake environment variables:
    PKG_CONFIG_SYSROOT_DIR=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot
    PKG_CONFIG_PATH=C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/usr/lib/arm-linux-gnueabihf/pkgconfig;C:/SysGCC/Raspberry/arm-linux-gnueabihf/sysroot/usr/share/pkgconfig
    All those folders are in correct place.
    The problem is it’s not building GTK+ support
    I’m getting build warnings, like:
    can’t find ffmpeg – ‘pkg-config’ utility is missing
    Which indicates pvk-config is not found.
    What is missing in the tutorial?
    I noticed pkg-config requires some complex installation on windows,
    https://stackoverflow.com/questions/1710922/how-to-install-pkg-config-in-windows
    #21967
    kennethone
    Ignore the last 2 lines above, that was for pkg-config not pkg-config-lite.
    Still the question remains, cmake cannot find pkg-config and it cannot build the GTK library
    I made sure the sysroot is synchronized, and I included  /usr/share/pkgconfig and /opt/vc  in the synchronized folders.
    Again, both of these folders contain .pc files. Thanks,
    • This reply was modified 7 years, 6 months ago by kennethone.
    #21991
    No problem. Please let us know the exact message you get now (after installing pkg-config and resyncing the sysroot). Please also double-check that you have set environment variables mentioned in step #7.
