Sysprogs forums › Forums › VisualGDB › Cannot debug with LPC4330
- This topic has 1 reply, 2 voices, and was last updated 9 years, 9 months ago by
June 29, 2016 at 21:50 #8499
Seidleroni
ParticipantI’m just starting with Visual GDB and I am trying to debug using the Segger J-Link. When I run the debugger, I get the following in my GDB Server Log. What do I need to do to get this working with my project?
SEGGER J-Link GDB Server V5.12h Command Line Version
JLinkARM.dll V5.12h (DLL compiled Jun 29 2016 17:47:05)
WARNING: Unknown command line parameter (SPIFI) found.
—–GDB Server start settings—–
GDBInit file: none
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: localhost only
Generate logfile: off
Verify download: off
Init regs on start: off
Silent mode: off
Single run mode: off
Target connection timeout: 0 ms
——J-Link related settings——
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
——Target related settings——
Target device: LPC4330_M4
Target interface: SWD
Target interface speed: auto
Target endian: littleConnecting to J-Link…
J-Link is connected.
Firmware: J-Link LPC-Link 2 compiled Oct 6 2015 20:18:25
Hardware: V1.00
S/N: 611000000
Checking target voltage…
Target voltage: 3.30 V
Listening on TCP/IP port 2331
Connecting to target…Connected to target
Waiting for GDB connection…Connected to 127.0.0.1
Reading all registers
WARNING: Failed to read memory @ address 0x00000F54
WARNING: Failed to read memory @ address 0xFFFFFFFE
Resetting target
Downloading 276 bytes @ address 0x00000000
Downloading 3972 bytes @ address 0x00000114
Downloading 4 bytes @ address 0x00001098
Downloading 4 bytes @ address 0x0000109C
Writing register (PC = 0x00000db0)
Read 2 bytes @ address 0x00000F54 (Data = 0xF7FF)
Read 4 bytes @ address 0x00000DB0 (Data = 0x4C0D4D0C)
Read 4 bytes @ address 0x1001FFFC (Data = 0x81000000)
Downloading 4 bytes @ address 0x1001FFFC
Read 4 bytes @ address 0x1001FFFC (Data = 0x42519CFD)
Starting target CPU…
…Target halted (DBGRQ, PC = 0xFFFFFFFE)
Read 1 bytes @ address 0x00000000 (Data = 0x00)
Reading 8192 bytes @ address 0x7FFFFFFF
WARNING: Failed to read memory @ address 0x7FFFFFFF
Reading 8192 bytes @ address 0x3FFFFFFF
WARNING: Failed to read memory @ address 0x3FFFFFFF
Reading 8192 bytes @ address 0x1FFFFFFF
GDB closed TCP/IP connectionJune 30, 2016 at 01:30 #8500support
It looks like the J-Link software might be getting invalid readings from the chip. Have you checked with Segger whether this chip is officially supported? Perhaps you are missing some configuration option of the J-Link GDB stub?
You can also try using OpenOCD instead. We can share our experimental script files for LPC4330 if this helps. -
