Sysprogs forums › Forums › VisualGDB › Cannot debug after upgrading to JLink software 5.10q
- This topic has 3 replies, 2 voices, and was last updated 10 years ago by
March 8, 2016 at 23:08 #7739
mlower
ParticipantAfter upgrade to JLink software 5.10q I cannot start debug session using VisualGDB. After successfully programming my nRF51822 VisualGDB halts without any error message. It looks like a breakpoint but I’m unable to hit “continue”. The same program can be debugged in Keil without any problems Below please find attached JLink logs from “JLinkGDBServerCL” window.
SEGGER J-Link GDB Server V5.10q Command Line Version
JLinkARM.dll V5.10q (DLL compiled Mar 4 2016 16:03:41)
—–GDB Server start settings—–
GDBInit file: none
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: localhost only
Generate logfile: off
Verify download: off
Init regs on start: off
Silent mode: off
Single run mode: off
Target connection timeout: 0 ms
——J-Link related settings——
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
——Target related settings——
Target device: nRF51822_XXAC
Target interface: SWD
Target interface speed: auto
Target endian: littleConnecting to J-Link…
J-Link is connected.
Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Mar 8 2016 11:17:15
Hardware: V1.00
S/N: 681310085
Checking target voltage…
Target voltage: 3.30 V
Listening on TCP/IP port 2331
Connecting to target…Connected to target
Waiting for GDB connection…Connected to 127.0.0.1
Reading all registers
Read 2 bytes @ address 0x000223CC (Data = 0xA805)
Read 4 bytes @ address 0x0001C110 (Data = 0xE7FEE7FE)
Read 2 bytes @ address 0x0001C10C (Data = 0x4700)
Resetting target
Downloading 4096 bytes @ address 0x00000000
Downloading 4096 bytes @ address 0x00001000
Downloading 4096 bytes @ address 0x00002000
Downloading 4096 bytes @ address 0x00003000
Downloading 4096 bytes @ address 0x00004000
Downloading 4096 bytes @ address 0x00005000
Downloading 4096 bytes @ address 0x00006000
Downloading 4096 bytes @ address 0x00007000
Downloading 4096 bytes @ address 0x00008000
Downloading 4096 bytes @ address 0x00009000
Downloading 4096 bytes @ address 0x0000A000
Downloading 4096 bytes @ address 0x0000B000
Downloading 4096 bytes @ address 0x0000C000
Downloading 4096 bytes @ address 0x0000D000
Downloading 4096 bytes @ address 0x0000E000
Downloading 4096 bytes @ address 0x0000F000
Downloading 4096 bytes @ address 0x00010000
Downloading 4096 bytes @ address 0x00011000
Downloading 4096 bytes @ address 0x00012000
Downloading 4096 bytes @ address 0x00013000
Downloading 4096 bytes @ address 0x00014000
Downloading 4096 bytes @ address 0x00015000
Downloading 4096 bytes @ address 0x00016000
Downloading 4096 bytes @ address 0x00017000
Downloading 4096 bytes @ address 0x00018000
Downloading 4096 bytes @ address 0x00019000
Downloading 4096 bytes @ address 0x0001A000
Downloading 4096 bytes @ address 0x0001B000
Downloading 192 bytes @ address 0x0001C000
Downloading 4096 bytes @ address 0x0001C0C0
Downloading 4096 bytes @ address 0x0001D0C0
Downloading 4096 bytes @ address 0x0001E0C0
Downloading 4096 bytes @ address 0x0001F0C0
Downloading 4096 bytes @ address 0x000200C0
Downloading 4096 bytes @ address 0x000210C0
Downloading 4096 bytes @ address 0x000220C0
Downloading 1016 bytes @ address 0x000230C0
Downloading 8 bytes @ address 0x000234B8
Downloading 4 bytes @ address 0x000234C0
Downloading 4 bytes @ address 0x000234C4
Downloading 8 bytes @ address 0x000234C8
Writing register (PC = 0x00021a00)
Read 2 bytes @ address 0x000223CC (Data = 0xB510)
Read 4 bytes @ address 0x00021A00 (Data = 0x68024812)
Resetting target
Read 2 bytes @ address 0x000223D0 (Data = 0xF7FF)
Read 4 bytes @ address 0x20007FFC (Data = 0x00021A35)
Downloading 4 bytes @ address 0x20007FFC
Read 4 bytes @ address 0x000006D0 (Data = 0x4C174916)
Read 2 bytes @ address 0x000006D0 (Data = 0x4916)
Read 4 bytes @ address 0xFFFFFFFF (Data = 0x4C174916)
Read 2 bytes @ address 0xFFFFFFFF (Data = 0x4916)
Read 4 bytes @ address 0x20007FFC (Data = 0x0A91D9CD)
Setting breakpoint @ address 0x000223CC, Size = 2, BPHandle = 0x0001
Setting breakpoint @ address 0x000223D0, Size = 2, BPHandle = 0x0002
Starting target CPU…
…Breakpoint reached @ address 0x000223CCMarch 11, 2016 at 19:28 #7755support
We have just retested it with the latest Segger J-Link v5.10s and could not find any problem.
We have tested the LEDBlink (BSP) project and tried stepping through the main() function and setting breakpoints – everything worked as expected.
On the first run the J-Link server prompted to update the firmware and we did that. Could you please verify that the problem still exists with 5.10s and after the firmware update?
March 12, 2016 at 10:38 #7765mlower
ParticipantVersion 5.10s works. Firmware update crashes Visual Studio but this happens only once so it’s not a big problem.
March 13, 2016 at 19:08 #7767support
KeymasterWow, strange. It did not crash on our side. If anyone else can confirm the crash, please send us dump file and we’ll gladly fix it.
