Calling to FastSemihosting from interrupts before initialization finished loops
Sysprogs forums Forums VisualGDB Calling to FastSemihosting from interrupts before initialization finished loops
  • #25766
    Gordon01
    It’s very simple to reproduce:
    From the main():
    1. Initialize RTC and enable it’s IRQ (every second)
    2. call printf(“hello world”);
    From RTC_IRQHandler:
    1. Just call printf(“RTC counter = %ld\n”, wvt_rtc_counter++);
    I’ve attached call stack, it gives clear explanation of the problem: WriteRawFastSemihostingData() is called from IRQ before InitializeFastSemihosting() finished.
    #25768
    Gordon01
    The microcontroller is STM32L071, running from MSI on 4.194 MHz.
    #25797
    No problem, we have published an update to the profiler framework that introduces a new setting: Disable interrupts during semihosting operations.
    Please try updating the framework and then set the new option to “Yes” in order to automatically disable interrupts during the execution of WriteToFastSemihostingChannel().
